LSA
noviasa
LSA
Postby noviasa » Fri Oct 10, 2008 10:37 pm
q1 If a airplane is licensed for two pax can you bring a baby or does a baby counts for a pax.
Afcourse with the baby you do not exceed the weight limit?
q2 What is the panalty if there is any in case you cannot fly with a threesome.
Thanks,
Novia
JK - 05 ready for take off
AndyG
Re: LSA
Postby AndyG » Mon Oct 13, 2008 8:03 am
Two seater is a two seater and that is that. There are all sorts of implications if you are caught flying three up.
One word of advice. Please don't do it
noviasa
Re: LSA
Postby noviasa » Mon Oct 13, 2008 8:55 am
thanks
Re: LSA
Postby RV4ker (RIP) » Mon Oct 13, 2008 12:18 pm
Kids under 2 are not considered pax and have to fly with adult (ie sit on lap). In airlines they give you lap strap for baby, so technically under 2 you would be allowed to fly pilot, mommy and baby/toddler. Once over 2 kids will need their own seat...
Not saying it right or wrong, simply that you could fly with a 2 seater with "3" up....
running for cover....
justin.schoeman
Re: LSA
Postby justin.schoeman » Mon Oct 13, 2008 12:58 pm
Seats, seat safety belts, harnesses and child restraint devices
91.04.14 (1) No owner or operator of an aircraft shall operate the aircraft
unless such aircraft is equipped, as applicable, with –
(a) a seat or berth for each person who is aged two years or more;
(b) a safety belt with or without a diagonal shoulder strap, or a safety har-
ness, for use in each passenger seat for each passenger who is aged
two or more;
(c) a restraining belt for use in each passenger berth;
(d) a child restraint device for each passenger who is less than two years of age;
(e) a safety harness for each flight crew member seat, incorporating a
device which will automatically restrain the occupant’s torso in the event
of rapid deceleration; and
(f) a safety harness for each cabin crew member seat:
Provided that a safety belt with one diagonal shoulder strap is permitted if the
fitting of a safety harness is not reasonably practical.
(2) Seats for cabin crew members shall, where possible, be located near a
floor-level emergency exits, the additional cabin crew member seats required
shall be located such that a cabin crew member may best be able to assist
passengers in the rearward facing within 15° of the longitudinal axis of the
aircraft.
(3) If the pilot-in-command cannot see all the passenger seats in the aircraft
from his or her own seat, a means of indicating to all passengers and cabin crew
members that seat belts should be fastened, shall be installed.
(4) All safety harnesses and safety belts shall have a single point release.
noviasa
Re: LSA
Postby noviasa » Mon Oct 13, 2008 8:39 pm
thanks!
