PTT ON BUZZCOM
- BOATCH
PTT ON BUZZCOM
Is daar iemand wat my kan help met die vervanging van n ptt knoppie. Ek wil n kleiner ptt knoppie inst ,kan ek enige tiepe gebruik.Op die intercom is daar n klein knoppie ,dit is die grootte wat ek wil installeer.
Re: PTT ON BUZZCOM
Enige "push to make, release to break" skakelaar.
Playing Planes.
ZU-BCW / ZU-BOC
Aerotrike / Challenger
ZU-BCW / ZU-BOC
- BOATCH
Re: PTT ON BUZZCOM
Tobie die draad wat op die ptt werk is dit nie die vesel tipe nie, en hoeveel draadtjies is da wat die skakelaar voer.
- ZULU1
Re: PTT ON BUZZCOM
Is this what you are looking for ?? The contacts are normally open, with the later Icom/ Vertex radios are 4 wire, the fourth wire merely switches to ground on the radio. The earlier Icom ICA20 series are three wire and sometimes the PTT switches a relay also normally to ground.
Zulu1
Zulu1
- AM mikro series PTT.jpg (47.6 KiB) Viewed 2979 times
- BOATCH
Re: PTT ON BUZZCOM
Zulu1 My problem is need to feed the wire throug the joystick and then fit a butten on the inside of the tube.At the moment it is hanging from the buzzcom int on the outside and always inthe way.
- ZULU1
Re: PTT ON BUZZCOM
OK, No worries, If possible that you can draw the stick, as well as photograph, measure the inside diameter with a vernier as close as possible (within 0,1mm). We use various PTTs for several applications and I will machine a suitable unit holding a button for you with a length of cable attached that you can join either inside the box (preferably). I have made them before using acetyl as a housing which will press into the top of the stick. I would imagine in Aliwal North that you dont have the same access to materials as we do.
Let me know
Paul aka ZULU1
Let me know
Paul aka ZULU1
- BOATCH
Re: PTT ON BUZZCOM
Thanks Zulu1 I wil do as soon as possible while the weather is not good for flying thanks for the help.
