Hi
I would like to know what you guys use to ensure the idling gap and piston position are the same on both carbs? (what kind of measuring tool)
When the engine is warmed up on the ground what EGT should I get?
Norml cruise EGT?
How many turns should the idling jet be turned out. Both exactly .5 turns out. Or could the two differ slightly. Looks like both my hex bolt and screw to the right of it is turned out more than the other one. Will take the air filter off just to make sure.
Please advice what I should do. Its on a Rotax 503
Karl
Carb setup - please help
Take to the sky
ZU-CBI
Aerotrike Scout
ZU-CBI
Aerotrike Scout
Re: Carb setup - please help
You are now getting technical Mr Karl.
Morph is the man!!!!!!
The tool you need is in my box in the hanger or make your own.
Two welding rods, knock the crap off, sand until smooth and you have some high tech instruments to put under the slide to see if both open to the same degree.
The fiddling with mixtures is another ball game.
Temp settings, RTFM. Or Morph.
Graham.
Graham.
Ya, I use a drill bit to check both carb slide heights and then adjust from there to get desired idle speed. What you must first check is that the throttle cables are balanced as this will cause problems when adjusting the slide heights, ie one slide wont come low enough to balance with the other.Once you get the desired idle speed balancing is quiet simple, just adjust one carb idle screw and the motor with run alittle rough and if you go the opposite way on adjustment it will start to run very smooth. Once thats done give the motor a short full throttle to clear oil build up in the crack casing and recheck idle speed. EGT temp not really effected coz you are on the slow running jet, EGT is mainly effected from 3/4 to full throttle as you are now on the needle jet, so if its running a bit high on EGT then drop the clip one notch, think there is only one notch above or below centre notch as this is where you should be to start with. Another point is if your motor has done high hours you should replace the needle jet and needle as these wear and effects fuel consumption and performance. Hope this helps.
Z-MRP
Z-MRP
The idle screw you referring to sounds like the air mixture screw, they should be the same and the number of turns out from full closed is in the rotax owners book, which if you are at sea level will be the standard settings give in the book. You can do a simple static check for mixture after running the motor on full throttle for a short while, kill the mags from this throttle position (Full) and remove your spark plugs, you are looking for a coffee color on the electrodes, you dont want to see any silver speckels as this is showing you are lean and probably high on EGT as well
Z-MRP
Z-MRP
- Duck Rogers
Karl, I've got an entire article about this somewhere. Do a search for carb tuning or carb setup. My procedure works everytime. I think there's a few guys on here that will testify to this...
- Koevoet
- I hate bird strikes
viewtopic.php?f=13&t=6514&p=63211&hilit ... ing#p63211Duck Rogers wrote:Karl, I've got an entire article about this somewhere. Do a search for carb tuning or carb setup. My procedure works everytime. I think there's a few guys on here that will testify to this...
Is it this one?
Very happy Scout Piloooot
- Duck Rogers
Yep, that's the one
- John H Arnold
- Learning to fly
Karl,
Jy sit met mense wat jou kan help op Wintervogel
Ronnie, Tobie, Ek en Shane kan jou help.
Jy moet net praat, Boetie
John H Arnold
Cessna 210TL
Aerotrike
Cessna 210TL
Aerotrike
Dankie John. Ek het met Shne oor die foon gepraat. Hy gaan my Saterdagoggend help. Ek is Vrydag af so het gedink om dit dan te doen. Hou van sulke goed en dis hoekom ek maar net solank vra op microlighters om n idee te kry hoe mens dit doen.
Groete
Karl
Groete
Karl
Take to the sky
ZU-CBI
Aerotrike Scout
ZU-CBI
Aerotrike Scout
