Koala 2 seater for sale - *SOLD*
Postby Duck Rogers » Fri Aug 15, 2008 8:07 pm
2 Seater side-by-side
Dual controls
Rotax 582 Mod 99 (Blue top)
E Box with electric starter
ASI
VSI
ALT
Turn and Bank
Tacho
2 x EGT
Fuel gauge
Fuel primer
Temp
Compass
Narco Com 810 panel mount radio
2 x headsets
Additional radiators
Back up electric fuel pump
Long range fuel tanks
Total time airframe 165 hrs
Total time engine -unknown (previous owners did not log hours) but recently stripped down, de-coked and inspected. All tolerances still well within specs.
Aircraft hangared at Baragwanath - FASY
R85 000.00 o.n.o.
Call me on 082 553 3295 or PM
Gerrie
EDIT:
1) Just to clarify, the plane was originally fitted with a Rotax 532. I see in the logbook it was removed and a 582 was fitted.
2) The empty weight is officially recorded as 259kg
3) Cruise speed on the Highveld is 65 - 70 mph because it has a "climb prop" fitted with a fine pitch.
Trikenut
Re: Koala 2 seater for sale
Postby Trikenut » Sat Aug 16, 2008 1:22 pm
Nice, looks a bit like a Pug though. :twisted: :shock:
No offence! vhpy
"Beware 16 year old here"
bluesmancoops
Postby bluesmancoops » Sat Aug 16, 2008 2:07 pm
does it have its ATF?
Mike Cooper
Postby Duck Rogers » Sat Aug 16, 2008 6:02 pm
bluesmancoops wrote:does it have its ATF?
Absolutely yes vhpy
The Agent
Postby The Agent » Sun Aug 17, 2008 12:55 pm
Uncle Duckie gaan jy nou ophou vlieg boeta of wat.
Ek sien da is nog n engilsman wat die selfde van as ek het da inni Kaar dink jy dis n goie ding as da 2 coopers vlieg inni Kaap.
Empty Toy Box
Busy Arranging for new toy.
Graham Cooper
Postby Duck Rogers » Sun Aug 17, 2008 6:08 pm
The Agent wrote:Uncle Duckie gaan jy nou ophou vlieg boeta of wat.
Nope.....ek gaan ophou Koala vlieg vhpy
"2 Coopers innie Kaap"...........beteken dit nou dat jy Kaap toe trek?
dvillier
Postby dvillier » Sun Aug 17, 2008 7:23 pm
I am interested in something like this. Some things I have to sort out.
Have PPL. Do I just need conversion and how does it affect my hours for my PPL renewal every year if I fly with a aircraft like this?
Any ideas?
Postby Morph » Mon Aug 18, 2008 9:24 am
You will need a simple conversion. If you convert with a Microlight Instructor then you will only be able to fly it on a Z code in this case Z050 (i.e. as a microlight on mpl). Then at the end of the year your Z code hours are MPL hours and the rest PPL. If you do your conversion with a PPL instructor then you will be able to build your PPL hours on it under the relevant PPL code. I am not sure if you will have to register the aircraft at CAA for PPL to get this code. it's worth giving them a call. I spoke to them regarding my BushBaby and they said it didn't have to be registered as PPL or MPL, just NTCA. Then depending on your licence you fly it with a Z code or the relevant PPL code.
kobusf
Postby kobusf » Mon Aug 18, 2008 1:11 pm
Hi Duck
I am a PPL pilot, and excuse my ignorance on MPL. If it can be flown on PPL : Is this a Non Type certified aircraft? May it be flown over built-up areas?
Stall speed?
Max all-up weight?
Any known issues?
Postby Duck Rogers » Mon Aug 18, 2008 7:34 pm
kobusf wrote:Hi Duck
Stall speed?
Max all-up weight?
Any known issues?
No need to apologise Kobus.
See the post before yours regarding the PPL issue. Yes it's NTCA. According to the Authority to Fly, no flights over built up areas for extended periods.
Stall speed is 38 mph.
VNE 105 mph
MAUW is 376kg according to the Manufacturer's specs although it regularly does 450 kg on the Highveld vhpy
No known issues........(not full of cr@p) very docile and forgiving.
Thanks Morph (^^)
German
Postby German » Mon Aug 18, 2008 7:48 pm
Duck you got pm
Robserve
Postby Robserve » Mon Aug 18, 2008 8:30 pm
Hi Duck !
Couple of questions.
Any instructors in Gteng re. conversion to Koala?
Where could i learn more about geotech wooden construction?
How is tbo calculated if no accurate record of Hrs on the 582 now fitted?
What is the advantage of the fine pitch climb prop as opposed to a slightly courser pitch?
Hope you can help, all the best, Rob.
Postby Duck Rogers » Mon Aug 18, 2008 9:13 pm
Robserve wrote:Hi Duck !
I've sent you a PM
kobusf
Postby kobusf » Tue Aug 19, 2008 5:05 pm
Hi Duck
If possible, please answer the questions from Robserve also on this forum. I am sure many others (including myself) are interested in the answers.
Kind regards
