RACOR FUEL FILTER/WATER SEPARATING FUNNEL (RFF Series)
PastMaster
Postby PastMaster » Thu Aug 14, 2008 10:51 am
Also Used in Aviation Applications - Aircraft approved (FAA)
Clean your fuel before it enters the Tank!
The ideal way to remove major dirt particles (100 micron) and most of the unsuspended water prior to it enters your vehicle or storage fuel tank.
It is still recommended to use a proper Racor fuel filter on the engine (which separates suspended unmixed water and filters the fuel even finer to the correct engine specification).
The Racor Fuel Filter Funnel (RFF) family is a new heavy-duty, fast-flow, filter-in-a-funnel that separates damaging free water and dirt particles from gasoline (petrol) , diesel, heating oil, and kerosene (paraffin) to include aircraft fuel .
This also allows you to inspect and control the quality of your fuel as you refuel especially out of fuel drums that are notorious for heavy water, rust & algae in them, all of which are very bad for the engine.
The RFF funnels are manufactured using industrial grade black electro conductive polypropylene. Carbon powder is injected into the plastic so that the RFF will conduct static electricity. The grounding capability of the RFF is an important safety feature.
RFF3C (medium)
224,1mm H x 137mm dia.
20 lpm
RFF8C (large)
24,9mm H x 211,6mm dia.
25 lpm
RFF1C (small)
149mm H x 87.2mm dia.
15 lpm
The filter is stainless steel coated with Teflon.
http://www.turboformance.co.za/NewWebsi ... unnels.htm
http://www.turboformance.co.za/NewWebsi ... iation.htm
Contact Ugene, he is very helpfull.
28 Waterfall Avenue
Riverside Industrial Park
Nelspruit
Tel: 013 753 2885 or
013 7533722 and
013 7532904
Our Mobile number: 083 675 5197
Fax: 013 753 2886
E-mail: info@turboformance.co.za
Microlight ZU-BBT Aerotrike Spirit II 6 Blade Power
grostek
Re: RACOR FUEL FILTER/WATER SEPARATING FUNNEL (RFF Series)
Postby grostek » Thu Aug 14, 2008 11:30 am
Any idea what the pricing is?
Kind regards,
Gunter Rostek.
PastMaster
Postby PastMaster » Thu Aug 14, 2008 12:51 pm
+/- R520.OO vat incl. For medium one.
