Please help.
can anyone advise regarding what electrode to use on the mild steel Rotax exhaust system.
I have a standard mild steel exhaust that has some type of ceramic (grey) coating on it.
Can it be successfully repaired?
Greg
Exhaust welding
Re: Exhaust welding
The grey coating, could well be an Aluminium coating, in which case you will have to grind it off at the crack. I would then gas weld.
Re: Exhaust welding
Were on the exhaust is the problem . Did it burn a hole or just a vibration crack . I can help need more info , Danie 0824528371.
