Radio interference
Kingpost
Radio interference
Postby Kingpost » Mon Jul 21, 2008 11:40 am
Hi All
I, once again, need to tap into the vast knowledgebase of this forum. Hopefully as I gain experience, I can soon help someone else in the same way.
I have recently upgraded my Icom radio with a Vertex 300 Standard and sended my Buzzcom intercom in for a service and conversion for the new radio. Everything came back and what a difference vhpy I Crystal clear and working. Until last week :? after a perfect landing taxing back to the hangar, all of a sudden the silence was broken by the interference from the engine over the headphones. Opened the pod and found a loose PTT wire that I soldered back but the engine noise was still there. (It is most possible that I accidently broke of the wire when I opened the pod.) Anyone had a similar problem before that can give me pointers as to where to search for the problem?
PS I just thought about the ANL (Automatic Noise Limmiter?) function on the radio and see that it is indeed turned off :oops: Will test and see if that is my problem this afternoon, any other sugesstions if I am not succesfull?
Raptor 582
Re: Radio interference
Postby Morph » Mon Jul 21, 2008 2:29 pm
talk to Zulu1, Paul, 08too 96oh 92four2
Kingpost
Postby Kingpost » Mon Jul 21, 2008 4:19 pm
Thanks Morph, will do so.
Raptor 582
ZU-CDW - Shark
Postby ZU-CDW - Shark » Mon Jul 21, 2008 8:23 pm
Hi Kingpost,
If all else fails check the following:
1. The Buzzcom system has a small power supply come noise reducer , usually where the fuse fits in to...it could possibly be faulty
2. The spark plug caps...one could have packed up resulting in the interference.
3. I recently had main battery problems where the battery would not retain charge after flights and the next weekend I will experience interference up until 20 minutes into the flight, and then the interference will decrease. I only use main bettery power as the radio battery no longer charges. After replacing the 12 V battery all was rectified.
Hope you do not have to go to these lengths to get the problem sorted.
Shark
0833036044
ZU-CDW
Kingpost
Postby Kingpost » Tue Jul 22, 2008 7:30 am
Shark I realy appreciate the response. Havent had time to get to the hangar yet, but will check out your advice. I will post my findings on here for interest sake.
Raptor 582
