Hello Guys,
I need to replace the Rotary Valve hoses that goes to the small oil tank reservoir. One of them has a crack and eaven that is no leaking, I want to replace both.
One RV hose run on the back of the magnetos plate and I have to remove that plate/bracket in order to have access to the clamp were is attached.
That plate/bracket is attached to the engine by four screws............ Two of does upper screws also hold the water outlet socket in his place so I will be carefull when removing does 2 screws.
So here are the questions:
Do the 2 remaining lower plate/bracket screws hold something else that the Magnetos plate? Or I just go ahead and remove them.
Any advise on doing this work? Do I need to remove something else to have access to that clamp/hose?
BTW, this Rotax 582 is a grey head, is top mounted on a Quicksilver UL and the spark plugs are facing up.
Thx for your time and help,
Isaac
Here is a pic of the Magnetos Plate (red arrow)
Rotax 582 Replacing Rotary Valve Hoses Advice/Tips
- Turbo_Boss
- Signed up at flight school
- Rotax Magneto Plate.JPG (72.6 KiB) Viewed 706 times
Re: Rotax 582 Replacing Rotary Valve Hoses Advice/Tips
Hi
I found that I could get to that hose clamp with a screwdriver between the plate and the engine and was able to replace the hose without taking the plate off. If your clamp is positioned differently then this may not work - in this case I have attached the relevant page from the repair manual that I hope will answer your question - is posted as an attachment because I don't know how to inclue it in the body of the reply as you did with your picture. Please let me into the secret for future postings
- ~$2 support plate.doc
- (162 Bytes) Downloaded 180 times
spurwing
