Hi Guys , I have an aircraft for sale and would like to post a picture with my advertisement. I am to doff to be able to insert the picture.Can one of you IT computer wizards please explain in layman terms to an old caveman how the hell to do it .
thanks
Blaine
082 808 3577
Posting a picture
Re: Posting a picture
I have written a document on how to do it for future reference.
Have had to break it into two parts due to the 100KB limitation of files.
Hope this helps others.
- AddingAPicture_Part2.pdf
- (72.81 KiB) Downloaded 188 times
- AddingAPicture_Part1.pdf
- (73.98 KiB) Downloaded 175 times
simple, press New Topic or Post Reply
If new topic, put in a subject in the Subject: box
In the main message body give your description, blah blah blah
Scroll down until you see the tabs at the bottom
Options Upload attachment
Select upload attachment
Now press Browse to look for you file (you must know where you saved it, it's somewhere on your PC)
select the file (NOTE: it must be smaller than 100kb other it will not work)
Click Add the file
then you can browse for up to 2 more
otherwise Submit once done
NOTE: To make the pics smaller do the following
1. right click on the start button and select Explore
2. Find your picture, usually in My Documents, My Pictures
3. Holding down the Ctrl key, left click on the various images you want to reduce in size
4. release the Ctrl key and right click on anyone of the selections, a drop down menu will appear
5. select Send to ... Mail recipient
6. It will open up a message, requesting you to make the pics smaller
7. an email message will open with all the pics in the attachments bar
8. Don't send the email. Select File Save Attachments
9. Save the attachments somewhere on your PC. Remember this for later
Now go back to the TOP and bpost the pics. 3 at a time. then post the next message and a reply and post the next 3
etc
Click Add the file
etc
- andreb
