Aviasport Analogue EGT gauge
Tracer
Postby Tracer » Wed Jun 18, 2008 10:03 pm
Hi Guys,
Wanna check if the gauge is "hooked-up"correctly. :?:
What I see is:
On the gauge there are 4 connectors.
1 connector is marked "+" (12v power source)
1 connector is marked "-" (neg wires from both probes)
2 connectors (other wires from probes)
Help... (**)
priester
Re: Aviasport Analogue EGT gauge
Postby priester » Thu Jun 19, 2008 7:45 pm
On the "K" type probes the red wires are neg and the yellow ones pos
Tracer
Postby Tracer » Thu Jun 19, 2008 10:04 pm
Thanks Priester, but those aren't the probes that I got.
Can't seem to get the gauge to work... :evil:
Wargames
Postby Wargames » Thu Jun 19, 2008 10:14 pm
Tracer wrote:Hi Guys,
What I see is:
Help... (**)
Tracer, I do not notice a earth/negative connector. I do not know the instrument, but I think the one in red is your earth, and the other 2 connectors that you listed last, is for you probes. This might mean that It can only take 1 probe. How many can it take?? Where is your manual??
Tracer
Postby Tracer » Thu Jun 19, 2008 10:21 pm
Wargames,
It is a dual egt gauge, unfortunately no manual...... :(
Postby Duck Rogers » Thu Jun 19, 2008 11:04 pm
For now, forget the +12v connector. It's probably for the backlight in the gauge, if it has one.
Your EGT probes may have black/white wires instead of red/yellow.
Take one probe only and connect one lead to "-" (neg. wires from both probes) connector and the other one to any of the other 2 remaining connectors except the 12v one.
Take a gas torch or something similar (even a cigarette lighter if you have to) and heat the tip of the probe. Watch for a reading on the gauge. If nothing happens, reverse the wires from the probe.
When you get a reading, leave it as is and make a note of what colours goes where. Repeat for the other probe until you have both working.
The two probes will share a common "-" neg. and seperate "+" pos. although technically, they're not really negative and positive.
Ps. for this exercise you have to have the probes uninstalled.
Don't worry, you can't burn anything out or explode or trash anything this way, even if the wires are reversed. An EGT gauge is a simple millivolt meter. It's not dependent on electrical input, except the light source vhpy
This method is guaranteed to work, unless something is trashed ie. the gauge or both probes :shock:
Tracer
Postby Tracer » Fri Jun 20, 2008 6:35 am
Excellent Duck, thank you... (^^)
I will defintely try this tonight and let you know. (I never even thought that the + wouldn't be needed)
Postby John Boucher » Fri Jun 20, 2008 8:10 am
http://www.aviasport.com/Instrumentacio ... ruple.aspx
I suggesto if u not comes correct, then contacto el Spanish companje - :lol:
Tracer
Postby Tracer » Sat Jun 21, 2008 6:30 pm
Bad Nav,
I tried the site, but my spanish failed me, so I decided to follow Duck Rogers' advice... It worked, Thanks Duck..... (^^) (^^)
Postby John Boucher » Sat Jun 21, 2008 7:07 pm
Our webbed feet friend is a walking marvel...... Duckie is the best!
Postby Duck Rogers » Sat Jun 21, 2008 8:10 pm
Tracer wrote:Bad Nav,
You're welcome.
Hope you made a note of what goes where, including a sketch, and keep it in your flight folio or plane's logbook :roll:
Tracer
Postby Tracer » Sun Jun 22, 2008 6:03 pm
I will now...... :lol: :lol:
