hi every one.
i recently took my 582 for inspection after 750hours.
the motor was opened up and crank was measured up and was found to be within the 60%wear limit after 600hours tbo as stated by the new law.
i am being forced now to replaced the crank and i dont want to argue tooo much with the ap.
as i understand the law,if the crank and engine components dont exceed the 60% limit, everything can be put back.
can any body out there clear this up for me..
thankx
582 inspection
Re: 582 inspection
The way I understand it is that less than 60% wear, crank can be refitted. Your next tbo would then be every 300hr's after the initial 600tbo. If you fit a new crank now it will give you another 600hr's to next tbo. Best bet find another AP!
Aviate Raptor
Re: 582 inspection
thanx. for the help.
an other ap is difficult to find unless u know of one..
the short block,is it still up for sale...?
Re: 582 inspection
Yes the short block is still up for sale, R5000.00. Where are you situated? I use Doug Wood from Port Elizabeth.
Re: 582 inspection
what is your email address??
Re: 582 inspection
the email that u gave me not working
cell nom please..
cell nom please..
