Sorry if this is a stupid question.
These safety wires [ to lock nuts etc] that everybody talk about. Is it a special type of wire or will any soft type wire that one can wind up do the job?
Safety wires
Re: Safety wires
Just be careful when you buy - I once used wire that kept snapping. Very frustrating because just as you have put a perfect twist in and want to fix the other end the damn wire snaps....
- John Boucher
Re: Safety wires
http://www.ultralightnews.com/pilotslou ... tywire.htm
Have a look at the above link..... some useful info there and will answer your question and help you apply!
- cjkrit
- Solo cross country
Re: Safety wires
Thank you very much for the useful information.
Will try to get hold of the right stuff.
Christo Kritzinger
Christo Kritzinger
- ZU-CDW - Shark
- First solo
Re: Safety wires
Hi Christo,
The wire used is stainlesssteel and is available from Aviation engines 0114554203. I use their product and have not had any hassles with it snapping etc.
Shark
0833036044
ZU-CDW
0833036044
ZU-CDW
Re: Safety wires
If you are not near aviation engines you can buy the wire at any nut and bolt supplier, like Topfast. Ideal thickness should be about 0.8mm and it must be Stainless Steel. They also use it in the sailing industry so any boat/yacht supplier would be able to supply.
- cjkrit
Re: Safety wires
Does anybody perhaps knows if there is a company in Bloemfontein which sells safety wire?
My cell if you can sms me: 0825760214
Christo Kritzinger
Christo Kritzinger
- REDROMAN
- Whats the right frequency?
Re: Safety wires
Hi Christo
Ek gebruik die safety wire wat Eskom gebruik.Baie geskik en het n groot rol by n vriend gekry.Laat weet my as jy wil he en dan maak ek n plan om dit by jou te kry.
0844302550
0844302550
Aliwal North
Re: Safety wires
Christo,
go to any nut and bolt supplier. It must be stainless steel, nothing else
- cjkrit
Re: Safety wires
Thanx vir daai draad. Waardeer dit.
Christo
Christo
