503 RPM
soekiwindni
503 RPM
Postby soekiwindni » Thu Jun 05, 2008 7:33 pm
What would the ideal RPM setting be for a 503 cruising straight and level at +/- 50 miles/h? Is 5800 rpm too high?
My engine goes up to 6900rpm at full throttle.... any problems with that?
thanks
Jodie
kloot piloot
Re: 503 RPM
Postby kloot piloot » Thu Jun 05, 2008 9:05 pm
5900 rpm straight and level, bar nuetral at 5000 asl.
Roel Jansen
ZU-IAR powered by BMW 1200
Biggles
Re: 503 RPM
Postby Biggles » Thu Jun 05, 2008 10:38 pm
5000 straight and level at 1500ft ASL one up. Take off it revs up to a smidgen below the red, 6900. That is with the three bladed AEROS prop.
Smokin'
Trike pilot
ZU-DLP
Winelands FAWN
Re: 503 RPM
Postby Morph » Thu Jun 05, 2008 11:43 pm
soekiwindni wrote:What would the ideal RPM setting be for a 503 cruising straight and level at +/- 50 miles/h? Is 5800 rpm too high?
thanks
Jodie
Yes, you are overreving the motor. Max rpm for 5 minutes is 6800. Max cruise RPM is 6500
The pitch of your prop blade is slightly low or you have a smaller prop, or your rpm guage is not reading correctly.
I would say your plane climbs great but obviously suffers on the cruise.
You want to cruise at 75% power which is about 5500 max
Wargames
Re: 503 RPM
Postby Wargames » Thu Jun 05, 2008 11:55 pm
Hi Morph, Make it 3000 posts and get it over with!!
nickjaxe
Re: 503 RPM
Postby nickjaxe » Wed Jun 11, 2008 10:34 pm
I have found the tachs that run off the 503 motor can be way out, i set mine up with a hand held laser type.
Nick.
