503 Instruments
Tracer
503 Instruments
Postby Tracer » Tue May 27, 2008 7:18 pm
When talking engine management/monitoring, what instruments do you guys suggest one uses on a aerie with a 503 air cooled engine?
EGT :?:
CHT :?:
Tach :?:
avgas
Re: 503 Instruments
Postby avgas » Tue May 27, 2008 7:24 pm
Tach
Balls to the wall
JFK
Re: 503 Instruments
Postby JFK » Tue May 27, 2008 7:27 pm
Tracer the only instruments on my 503 for the moror is a Tach
Why Wonder If it can Fly Just try
Wargames
Re: 503 Instruments
Postby Wargames » Tue May 27, 2008 7:57 pm
Tracer,
You can use what I am currently using, and that is nothing!! :shock: :shock:
That is the best way to fly, with total trust on your engine and aircraft.
But if you are really starting to get into things, then you can start to get some instruments, like a rev counter. And then graduly work your way to all you want.
Every instrument show something different of the engine, so you must use them in total to get the bigger picture.
Biggles
Re: 503 Instruments
Postby Biggles » Wed May 28, 2008 3:00 am
I have the tach and EGT fitted. A while back I fiddled with one of the EGT sensors and it stopped working... I have not missed it iether. EGT will tell you if you are running lean or rich. Would rather replace it with a feul flow guage... but that is just a nice to have.
CHT is more for watercooled engines and I don't believe any real benefit would be had on the 503
Tach is useful for establishing a cruize altitude. And being able to hold revs means that you don't wander around altitude wise. But you can mostly fly by ear. I don't believe I use the tach in circuts at all. Tach is also good for when you do mag checks as the rev drop is often not audable but you can see the needle dip.
Trike pilot
ZU-DLP
Winelands FAWN
Tracer
Re: 503 Instruments
Postby Tracer » Wed May 28, 2008 6:40 am
Excellent, guys thanks.
In my opinion the Tach is a must, like Biggles said, not really for use in circuit, but it helps to maintain cruise altitude etc.
Thanks for the advise. vhpy
Re: 503 Instruments
Postby Morph » Wed May 28, 2008 9:50 am
Tracer,
if you have nothing go the MGL EMS-503 unit. It's got 2 CHT, 2 EGT, rpm, Hobbs and flight timers built in. Everything you need apart from the EGT and CHT probes to safely monitor the 503 motor. Of the lot, EGT and rpm are the most important.
MGL wrote:The complete engine monitor for the popular Rotax 503 DCDI engine.
A programmable rev counter allows this instrument to be used with other makes of air cooled two stroke engines.
Rev counter, hobbs, flight timer, 2 channel EGT and 2 channel CHT plus alarms. All precision measurements. Easy to use and the best way to go.
I have attached the manual for you to have a look at.
EMS-503.pdf
(131.57 KiB) Downloaded 255 times
3wheels
Re: 503 Instruments
Postby 3wheels » Wed May 28, 2008 10:14 am
Tracer,
Check out the MGL range, the product is really good, I have the Stratomaster Xtreme and honestly, if I bought a plane it would be the first thing that would go on.
Just my 2c
P.S Got any flying in lately :?:
ZU-"Charlie"YV
Tracer
Re: 503 Instruments
Postby Tracer » Wed May 28, 2008 1:04 pm
I will take a look at the MGL range, thanks
3Wheels,
No. haven't been in the seat for 2 weeks.
Hoping for Staurday....
REDROMAN
Re: 503 Instruments
Postby REDROMAN » Wed Jun 25, 2008 8:41 am
Want to put an egt om my 503.Is it worth the wile and can it warn you for possible "hot spots"especialy on decending - throttle off for some time.
Aliwal North
Re: 503 Instruments
Postby Morph » Wed Jun 25, 2008 9:16 am
Absolutely, that is it's value inflight
being able to monitor your EGT's give you the following advantages
1. You get to balance your carbs perfectly (egt's within 25 deg of each other)
2. On takeoff you can monitor your engine performance and you will typically see your engine runs cooler at max throttle than at other times (assuming you are not over-revving of course)
3. you can select the best cruise setting based on the EGT, (lower EGT's better)
4. You can immediately detect a lean condition (EGT's shoot sky high) Crack in the carb rubber etc.
5. Cruise decents, you can select the best rpm without running in a hotspot
6. You can pitch your prop correctly. Changing your pitch is like changing gears. The courser the setting the more the motor labours (loading). Your EGT's will increase when loaded.
