Close call - don't let this happen to you!
andreb
Postby andreb » Mon May 26, 2008 11:01 am
Re: Close call - don't let this happen to you!
Postby John Boucher » Mon May 26, 2008 11:46 am
hmmmmm A friendly reminder who to thank methinks.... May the Force be with you...
Petrodactyl
Postby Petrodactyl » Mon May 26, 2008 12:04 pm
Pilot error!! Great, get the Almighty to bail you out when you forget to check your fuel. If they hadn't made it the article could have been about the Darwin awards. Instead they chose to turn their basic mistake into an affirmation of faith.
Maybe this is a bit strong. There are many things that are outside our control in the unnatural environment we have chosen to play in. There is a strong element of Grace in any completed flight. But giving your Maker extra work because you run out of fuel......... :?
Christian Carver
Go Fly a Trike!
ZU-BBU
Postby John Boucher » Mon May 26, 2008 3:50 pm
The Boss upstairs is the Spiritual Fuel Jockey but I agree not just there as the emergeny red button required situation!
PRE-FLIGHT SAFETY!!!!!!!! ##
