HELP PLEASE
Graham Mac
HELP PLEASE
Postby Graham Mac » Sat May 17, 2008 11:08 am
im flying a rotax 582 and on take off the engine suddenly loses power and comes back then loses power and comes back again.checked fuel. replaced fuel filters. plugs.and clean fuel.power check on the ground is perfect.and power loss is intermitent.has anyone experienced something similar and could advise possible causes.could it be fuel pump?new diaphram has been fitted.new stator coil and magnet flywheel fitted.can a electronic box fail then work again.??im at a loss as to what it could be...very scary loosing power on take off.any advice???? :? :?
Graham
Re: HELP PLEASE
Postby Morph » Sat May 17, 2008 12:08 pm
Start your plane and rev it up to max, switch both mags off and then back on again before the motor stops, i.e. 1/2 sec etc. Note the engine does not immediately die, takes a few secs. Now is this the same sensation as you are getting in the air? If so then your problem is electrical with the Ducatti ignition system
With fuel problems the motor won't suddenly die. It will be a more gradual loss of power, i.e. a few seconds more as opposed to 2-3 seconds. I have had fuel starvation problems before and the motor starts loosing power, coughing and farting. Switching an electric pump on doesn't suddenly bring it back to life either, takes a few seconds more of coughing and farting and then comes back up.
Hope this helps
Graham Mac
Re: HELP PLEASE
Postby Graham Mac » Sat May 17, 2008 2:10 pm
thanks Morph
im up for any advise i can get right now
REDROMAN
Re: HELP PLEASE
Postby REDROMAN » Mon May 19, 2008 7:59 am
Had the same expierience at one stage.Found a piece of silicone in one of the jets.Dont know where it came from,but it happened.
Aliwal North
Graham Mac
Re: HELP PLEASE
Postby Graham Mac » Mon May 19, 2008 4:13 pm
Hi REDROMAN...We have cleaned carbs jets needle n seat..am replacing on both carbs just as a precaution.i think we may have found the problem...still to test..we managed to get the engine to loose power on ground test and found after switching both mags off immediately,that one carb bowl was dry of fuel.checked pump..nothing wrong..then noticed vacuum pipe from pump to sump kinked..restricting vac flow.rerooted pipe and tested..reving normaly again.have not test flown yet but will see after carb service
Thanks for the input..much appreciated
Re: HELP PLEASE
Postby Duck Rogers » Mon May 19, 2008 7:36 pm
GRAHAM MAC wrote:then noticed vacuum pipe from pump to sump kinked..restricting vac flow
Graham, not sure what you mean by "vacuum pipe from pump to sump"
Are you referring to the pulse line? From the engine to the pump? If so, then both bowls would/should have been empty as this pipe is what makes the pump "tick"
You wanna phone me? I have a theory for you. Or drive round the corner for a chat about it.
0825533295
Graham Mac
Re: HELP PLEASE
Postby Graham Mac » Tue May 20, 2008 6:27 am
thanks Duck ill call you to set up time to meet
Graham
LarryMcG
Re: HELP PLEASE
Postby LarryMcG » Tue May 20, 2008 2:24 pm
Use a long runway, and the whole thing!!
Good luck
LM
Still Flying
Re: HELP PLEASE
Postby John Boucher » Tue May 20, 2008 3:11 pm
Had a similar experience with my 582. As Morph mentioned my problem lay with the Ducati coils. One of the wires had burnt off inside at the base of the Ducati Male/Female connector. Everything checked out fine doing checks, did a game count and in flight when we trurned out left and climbed the engine would lose power. Straight and level everything normal, same result each time....
I cut the connectors off and replaced with a different connector system! Problem solved.... Hope this helps!
Graham Mac
Re: HELP PLEASE
Postby Graham Mac » Wed May 21, 2008 7:03 am
thanks bad nav
i will check out the connector on the ducati coil..it is a bit suspect as one of the wires the insulation/plastic coating has gone a bit soft/spongie
thanks for the advise
Graham
Re: HELP PLEASE
Postby John Boucher » Wed May 21, 2008 10:47 am
Graham
Let us all know what transpires....
Graham Mac
Re: HELP PLEASE
Postby Graham Mac » Wed May 21, 2008 2:36 pm
Will do John
we will put new carb components in on friday and test fly....hope it solves problem
will check ducati box connections and hold thumbs
if you dont hear from me after that..youll know it didnt work :lol: :lol:
Graham
vernon11
Re: HELP PLEASE
Postby vernon11 » Wed May 21, 2008 9:18 pm
Hi Graham Mac.
I had the same problem. on several accasions I found one bowl empty. It was really nerve racking. I fitted new pump kit. Float needles. Fuel pipes. The problem seems to have been solved. Still don't know what the cause was.
Cheers.
Graham Mac
Re: HELP PLEASE
Postby Graham Mac » Thu May 22, 2008 8:01 am
Thanks vernonII
im going down the same route
Cheers for the input
Graham
Boer
Re: HELP PLEASE
Postby Boer » Fri May 23, 2008 11:50 am
Hey Mac,
Have you got fuel in the fuel tank?
ZS WOA (Meisie Ferguson)
Ploegskaar No. 1
