Density Altitude
jacester
Density Altitude
Postby jacester » Fri May 09, 2008 1:49 pm
This is something that I find is more pronounced on the Gyro since we fly in the heat of the day, especially when heavy. The rule of thumb density altitude as derived from the flyingmountains website converted to celcius and the way I understand it is as follows. Let us use 4500 feet as example.
1. 4500 divided by 1000 *1.94=8.75. This is the deduction from the standard sea temperature of 15 degrees Celcius giving the standard altitude temperature of 6.25 degrees centegrade at 4500 feet.
2. Current temperature is 26 degrees. Degree difference is 26-6.25=19.75.
Multiply temp difference by 108 feet per degree. 19.75*108=2133 feet.
This implies that the density altitude is 4500 +2133=6633
I order to remember this.
1.94 is the standard factor to calculate standard density temperature.
108 feet per degree difference from standard temperature
Even I can remember that. According to the web site the density altitude will not be out by more than 300 feet.
Re: Density Altitude
Postby John Boucher » Fri May 09, 2008 7:36 pm
“Safety: reflect on it or it may reflect on you.”
DENSITY ALTITUDE
Looking through accident reports from the past several years for a particular time of year can reveal some interesting and instructive information. We hear lots of stories about the dangers of ice and snow and freezing in winter, but what are some of the hazards of this time of year that have led pilots to come to grief? One of the items that appear in too many accident reports as a contributing factor is Density Altitude. Pulling the threads of accidents leads us to some important safety considerations for flying in the warm, summer months. In most of the accidents the pilots were qualified for the intended flight and there appeared to be no mechanical problems with any of the aircraft prior to their contact with the ground. All of the aircraft were at or approaching their gross weight and temperatures were above standard, in the 20 to 30 degree Celsius range
In ground school, we generally discuss, in one form or another, the concept of the “4 H’s”: high, heavy, hot and humid, also known as altitude, aircraft weight, outside air temperature and humidity level. Each of these is a factor affecting aircraft performance. Maneuvering an aircraft increases G loading, this increases wing loading and stall speed, just to put icing on the cake. Our “ideal” scenario for light aircraft operation would be low altitude, a light load and a cold, dry day. In most of the DA accidents, at least three of the four H’s were on the wrong side of pretty, and the pilots were maneuvering just prior to the stall and subsequent crash. One of the key windows we have for predicting reduction in aircraft performance is to understand the concept of density altitude. We have all learned how to calculate density altitude in ground school and probably retained that information right through the written exam. Understanding how the concept relates to aircraft performance and making the needed allowances for the effect it has might just save your life. In simple terms, density altitude is pressure altitude corrected for temperature. It gives us what I like to think of as the aircraft’s experiential altitude: the altitude at which the aircraft “thinks” its flying. If we want to be a bit more specific, we can determine the density altitude ourselves and work from there. Using our E-6B Flight Computer, we look in the window for True Airspeed & Density Altitude, set the air temperature over the pressure altitude and read the density altitude.
While humidity is not nearly as significant a factor as temperature and pressure or weight, it does have adverse effects on aircraft performance. Given two masses of air with the same temperature, the moist air mass will always be less dense. Water vapour in the air affects both engine power output, with piston engines, and the amount of lift an airfoil can produce. High levels of humidity, in effect, increase the density altitude by decreasing the ambient air density. What all these calculations demonstrate for us is that heat, altitude, weight and humidity can seriously degrade aircraft performance. In high density altitude conditions, our take-off roll will be extended, our rate of climb will be reduced and our aircraft’s ability to maneuver will be impaired. As pilots responsible for ensuring safe flight, what we need to know and understand about these factors is the specific ways they will affect the aircraft we are intending to fly.
A hot day does not cause an accident. Neither does operating an aircraft at gross weight or in a light drizzle or taking-off from an aerodrome with a high density altitude. However, coupling these factors with a serious underestimation of their effects on performance and a pilot who thinks he or she can maneuver an aircraft in the same manner and expect the same performance as at sea level on a normal day can set the stage for a tragic outcome.
Just as we know visibility, turbulence and icing are factors that must be considered before commencing flight, so too are heat, altitude, weight and humidity. Knowing what to expect from an aircraft under any particular flight conditions allows us to make the decisions that will result in a safe, enjoyable flight
Marc G
Postby Marc G » Sat May 10, 2008 9:18 pm
Just a thought...
Density altitude calculations usually deal with the loss of air density (in South Africa at least, as our climate is generally warmer than ISA standard atmosphere), as a result of temerature and pressure changes (T +, P-), against ISA conditions. Bear in mind that on a cold winter day, your aircraft will perform better than the book says! Almost makes you want to get out of bed in the morning!
In order to maintain the same amount of lift, with a parcel of air that is less dense, one of the other factors of lift has to be increased, to compensate for the loss of density. The only ones which can really be altered are airspeed (or "wing airspeed"), or angle of attack.
for those of you who can't remember:
[Lift = (0.5) x density x (velocity)squared x wing area x lift coefficient(affected by wing shape, angle of attack)]
We know that the angle of attack is limited to stalling angle, before lift decreases.
A fixed wing moves relatively slowly, compared to a rotor wing (I'm speaking specifically about the the actual wing), to create the required lift. In order to compensate for the loss in density, the speed of each would have to increase proportionally (assuming most efficient angle of attack). This would mean a relatively small increase in speed of the fixed wing, in comparison to the larger speed increase of the rotor wing.
As I understand it - this why fixed wings don't suffer from density altitude as badly as rotor wings.
Am I correct? I have never done any rotor wing theory courses, so just trying to figure it out. Any comments? Corrections?
... Just thinking about it...
tthierry
Postby tthierry » Tue Jun 03, 2008 10:16 am
You can compute a density altitude using http://nav3000.free.fr/moteur/conversion/form_deriv.php
Postby Morph » Tue Jun 03, 2008 11:52 am
Marc G wrote: As I understand it - this why fixed wings don't suffer from density altitude as badly as rotor wings.
Interesting thought process. A fixed wing aircraft needs to travel faster through the air to generate the same amount of lift as on a cool day. The engine (negatively affected by thinner air) and the prop (a wing negatively affected as well) need to work harder to produce the needed thrust to overcome the drag and generate sifficient lift to take off and to fly. However the landing, relies on the forward inertia of the aircraft and not as much on the engine at this stage and the wings are now flying normally in this parcel of air. So at this stage of flight, except for actually taking up more runway the actual landing is the same.
A chopper on the other hand has to produce sufficient lift from the rotor (a wing) by engine power alone. I'm not sure if the high wing loading of the chopper would be any less efficient than a fixed wing. But to me what is criticial is if the chopper is not in forward motion, using the movement of air to further help with the lifting characteristic of the wing as in the case of a fixed wing, then the motor has to do all the work. I suppose coming in to hover and land now is so highly dependent on the reduced performance of the motor, unlike the fixed wing.
How does this affect the Gyro? This needs forward motion to maintain lift
I am just waxing lyrical here and welcome comments form others.
Users browsing this forum: Bing [Bot] and 9 guests
