Rotax 582 VP Prop
NVD
Rotax 582 VP Prop
Postby NVD » Thu Sep 08, 2005 12:59 pm
Would like to know if a 582 would be able to swing an in-flight adj prop (possibly IVO) and what the benefit would be.
The installation would be in a tractor configuration on Bushbaby size craft.
skybound®
Re: Rotax 582 VP Prop
Postby skybound® » Mon Sep 12, 2005 10:19 am
NVD wrote:Would like to know if a 582 would be able to swing an in-flight adj prop (possibly IVO) and what the benefit would be.
It is quite a common installation within the Kitfox fraternity. The Ivo and a 582. Although a 912 would probably be better.
Postby Morph » Mon Sep 12, 2005 10:33 am
You don't match engine to prop, you do it the other way around, i.e. prop to engine. Select the engine i.e. 582, and then determine the size, pitch weight etc for the prop. Then you go to IVO and give them these specs and they give you the correct prop that the engine will easily swing. There is no reason why a 582 can't swing a correctly matched prop.
582 and Adj prop
Postby Boet » Tue Oct 04, 2005 8:39 pm
I have a Ivo 3 blade adjustable prop for you. New electric motor fitted. 68" dia. Gooi me a PM
VP
Postby Boet » Fri Oct 07, 2005 9:34 pm
Jaaaa, swaer....... :roll: :roll: :roll: :wink: **
Junkie
Postby Junkie » Sat Oct 08, 2005 1:51 pm
Boet my main man.. kan u build me wun o thoos varibal speed eriplains thet goes stait up in the skye wif likkle wings in the midel of the fusealarge and the propelur is bigur than the pilut :lol: :lol: :P :P :wink:
u probably guessed the winds chucking along and im bored stiff.
J.U.N.K.I.E 's
No credit / No returns
FAWGie
Postby FAWGie » Wed Nov 02, 2005 9:39 pm
Some tests done here this week on an aerie with a 912S motor and VP 3-blade prop....with same RPM setting in cruise, they got an extra 15mph going from fine to course pitch....
