Running in 582 Rotax
Kingpost
Postby Kingpost » Tue Jan 22, 2008 4:33 pm
Hi All
I have replaced the shortblock (582 Rotax) on my trike and now have to run it in. I have the correct run in procuders for this but what they dont mention is how to keep the Water Temp. below 80 deg. cel. while doing this. Can anyone sugest the right way? One sugestion was to fit a water hose to the cooling system, but wont the cold water crack the head?
or is it permitted to let the temperature rise to a certain extend while running in the engine?
Raptor 582
RudiGreyling
Postby RudiGreyling » Wed Jan 23, 2008 8:11 am
I am not en expert, but here is what I've read.
During run-in never, never let any of the temperatures run over their limit, not even for a short while. If it hits the upper limit stop immediately, let cool down, and try that cycle again. How you treat your motor during this first run in, and first couple of hours, will make a big difference in the long term.
Does you 582 have a thermostat in? if so then I think it is ok if you expand the water capacity during run-in. How exactly I don't know.
http://www.RudiGreyling.com
Kobus
Postby Kobus » Wed Feb 06, 2008 11:57 am
I need to do the same. I thought of blowing a "mist " from a high pressure washer truogh the radiater while running the motor. Not sure if this will work.
The higher, the faster, the safer.
powerfly
582 runin
Postby powerfly » Wed Feb 06, 2008 7:53 pm
Best to call is Dave Miller at Solowings.
Just get in and fly the trike. Take your runin sheet with you and try to keep to the times specified.
Have you got the run-in sheet?
Noel
Noel McDonogh
World of Wings Flight School
Umkomaas Airfield
info@wowflight.co.za
0721175130
John Young
He retired last week
Postby John Young » Thu Feb 07, 2008 4:31 am
powerfly wrote:Best to call is Dave Miller at Solowings.
He retired last week. Lekker ou !!!!
John ZU-CIB
Kingpost
Postby Kingpost » Thu Feb 07, 2008 6:49 am
Yes, I have the run-in sheet vhpy , I spoke to the clever guys that do this alot and by the looks of it Kobus's advice is spot on. Will try to spray water on the radiators in order to keep the temperature at bay. Will let you know how things turn out. Thanks for the advice.
Raptor 582
