fuel injection
skidmark
fuel injection
Postby skidmark » Sun Dec 02, 2007 9:05 am
Dumb question...can you fuel inject a Rotax 503? :? If yes what are the costs and how? Consequences? Where do get the stuff? If not why? This is just a question to get a discussion going. I'm happy with my with the way things are, but my arrie often cuts out, on landing have to pull choke or restart on the runway. This is when I do a glide approach just before the threashold and run at idle.
ZULU1
Fuel Injection
Postby ZULU1 » Sun Dec 02, 2007 5:29 pm
Take a look at this...
viewtopic.php?t=5909
Ciao Paul
Biggles
Postby Biggles » Mon Dec 03, 2007 8:09 am
I seem to remember, when I first started being interested in microlighting, an article on someone that had fitted an opel injections system to a rotax... I have no idea what engine it was I would imagine a 582... did a quick search and couln't find it mayabe it was on another site.
Trike pilot
ZU-DLP
Winelands FAWN
Biggles
Postby Biggles » Mon Dec 03, 2007 8:12 am
Trike pilot
ZU-DLP
Winelands FAWN
Miskiet
Postby Miskiet » Mon Dec 03, 2007 11:47 am
Hi Skidmark,
My 503 did the same a while back - one of the idle jets was blocked. A good blast with air and she was right as rain again. The 503's idle speed needs to be quite high - too low and you'll get similar problems.
Fuel Injection
Postby John Boucher » Fri Dec 14, 2007 5:53 am
A Hirth 3202 uses fuel injection. Could this system not be adapted to a 582?
ZULU1
Fuel Injection
Postby ZULU1 » Fri Dec 14, 2007 6:40 am
Hiya Bad Nav
For info I am using a Daewoo throttle body and injectors on my HKS, its the same as a half a 1400cc. I see no reason when i have finished the HKS project that the same system could be made to work with a 503/582. It requires a heap of plumbing though. My thoughts are that the 503/582 deliver sufficient power/economy why bother. It just adds complications. As a two stroke with related emission related problems it seems pointless spending time on a project without "legs". The 912 is a different kettle of fish and I may do that project next.
The sole reason for the HKS project is to give it more power and in line with a 582, but with the 1000 hr tbo of a four stroke. I also believe the HKS will be around for a long time as the US market uses many. It will also offer an economical alternative to the part 24 crank change "paperwork problem" of the Rotax motors.
Got to prove it though..someones got to do it first..
I am very fortunate in the fact that a foundry in our complex makes high grade cast ally manifolds for the street racing fraternity in the US and Oz. They incidentally make the inlet manifold used on the Oz made Spitfire. I have superb resources available so if anyone wants a manifold casting. It may be in stock !
eish Zulu1
Boer
Fuel Injection
Postby Boer » Fri Dec 14, 2007 9:04 am
Paul
Did you urine-inject your bed this morning, Posting a reply at 6:40, you must have! :oops: At your age the plumbing shouldn't leak.
Don't let the pressure get to you.
Jacques
ZS WOA (Meisie Ferguson)
Ploegskaar No. 1
smallfly
Postby smallfly » Wed Dec 19, 2007 10:15 am
Hi Skid
I would say the easiest way would be to use a blow through carburetor,
wich requires positive pressure from a high pressure pump.
Delorto comes to mind.
The old vw variant used a single injector system, it was commonly known
as a sp feul injection carburetor, don't know if they still make them.
Another option would be to look at the injection systems used
on motorbikes, you get them on two strokes as well,
but do you really want to add to the components wich can fail ?
skidmark
Postby skidmark » Fri Dec 21, 2007 8:05 am
He! He! I see the Boere are still taken the piss out of the the Zulu's! :lol: :D :wink:
Fuel Injection
Postby John Boucher » Sun Jan 13, 2008 10:52 am
Hiya Zulu1
Whats the progress on the HKS project?
ZULU1
HKS
Postby ZULU1 » Mon Jan 14, 2008 6:16 am
Howzit Bad Nav
The throttle bodies (Daewoo), exhaust, fuel pumps and electronics are complete and will "time permitting" collect tomorrow jhb. and then its ground run output checks. It looks at though we are in the 67 ish Hp possible range with first trials. Then if all is well we will be making the cast ally inlet manifolds patterns etc. Make the correct ecu boards and then a kit.
I intend to do a back to back thrust test in Jhb with a 582 on the scales to give us an idea. What is nice is the egts/chts are being used as a safety input to the ECU. This is a really good feature as you technically cant poke the motor as it is fully controlled.
If all is well the same electronics etc will work on the 912 as well, just manifolds different. The HKS has the same carbs as the 912.
It may well be a 1000hr alternative to the two strokes at a similar price, fingers crossed. Still a heap of work though. And locally made kits, spares etc. What a pleasure.
Someone has got to beat these type 24 rules !! most probably call it (if effective) HKS700/24 efi
I will need a forum "law adviser" to help with the paperwork in the very near future please any volunteers ??
eish Zulu1
Fuel Injection
Postby John Boucher » Mon Jan 14, 2008 8:34 am
How about a kit on a JAB 80/85 motor?
