Exhaust Hanger Rubbers.
Postby Boet » Wed Nov 21, 2007 8:02 pm
I got seriously pissed off at those over-priced larney looking short-life rubber exhaust hangers. I tied cheap :oops: , and then EXPENSIVE :shock: Neither lasts very long. So I put ye ole thinking cap on, and this is what I coocked up. Voila :!: No more broken exhaust hangers. ( Admittedly, it may NOT look larney, BUT it lasts......... :D
Ex hanger.JPG (52.72 KiB) Viewed 2121 times
Postby Duck Rogers » Wed Nov 21, 2007 9:26 pm
Nothing on my plane looks larney. The plane doesn't know that though :D See if I care, it flies just the same :D
Nothing wrong with that Boet !!!!
Mogas
Postby Mogas » Wed Nov 21, 2007 11:22 pm
A naailok nut forward of the firewall :shock: what will the thought police say about that?
Serriasly Boet, what is that rekken (rubber) mount from?
Nottaquitta
Aerosan
Postby Aerosan » Thu Nov 22, 2007 5:50 am
Duck Rogers wrote:Nothing on my plane looks larney. The plane doesn't know that though :D See if I care, it flies just the same :D
Nothing wrong with the plane its the pilot that looks that old that bothers me :twisted: :twisted:
Boet those hangers looks great and if you ask me they look larney toooo :wink:
Postby Boet » Thu Nov 22, 2007 8:45 pm
Sort of looks like sushi :D I have a lot of 25mm rubber radiator pipe offcuts. That is the black part. The white stuff is poly urethane glue/seallant. ( The stuff we glue the windows in with.) For the mounting hardware you will need 2 X 35mm X 6 mm bolts, 4 25X6mm "penny washers and 2 X 6mm nuts. Hammer the washers in the same curvature as the 25mm rubber hose. Drill 2X 6mm holes in the rubber hose. Put washer inside and force bolt thru, washer outside and tighten, repeat opposite side. Blank one side of hose with whatever and fill up with poly-u.
Mogas
Postby Mogas » Fri Nov 23, 2007 1:48 pm
Another good tip from Boet, thanks.
This is exactly what NTCA is all about 8)
Nottaquitta
ICEMAN
Postby ICEMAN » Fri Nov 23, 2007 2:33 pm
Mogas wrote:Another good tip from Boet, thanks.
Nicely done and nicely said Mogas......... lets just hope Boet doesnt get a fine from a newly appointed CAA eishpector with his fine book...... :?
ZU-CPW..... t/bird mk2
Hoedspruit Civil Airfield
Hangar 8
Arnulf
Postby Arnulf » Fri Nov 23, 2007 8:41 pm
Why should he get a fine? To me its quite obvious that this is a genuine aviation part. So far I have not seen a single motorcar using that type of exhaust rubber hanger.
Arnulf
John Young
Touché
Postby John Young » Sat Nov 24, 2007 4:52 am
Arnulf wrote:Why should he get a fine? To me its quite obvious that this is a genuine aviation part. So far I have not seen a single motorcar using that type of exhaust rubber hanger.
Touché !!!!
John ZU-CIB
Postby Duck Rogers » Sat Nov 24, 2007 7:11 am
Gee daai bek 'n bietjie jêm asseblief :D
Postby Boet » Thu Nov 29, 2007 7:54 pm
More pics :D
exoz rubbers.JPG (50.78 KiB) Viewed 1964 times
skidmark
Postby skidmark » Fri Dec 21, 2007 8:16 am
From the picture I thought you might have swiped a couple of californian rolls from the sushi bar....He! He! looks good. You could get a friend to injection mould sometime...just a thought?
PMarshall
Postby PMarshall » Fri Dec 21, 2007 9:46 am
Must admit I have never had a broken exhaust mount in many flying hours. Maybe due to only using well balanced 3 blade props. You can purchase the ruber mountings from rubber products and mouldings, I don't know what they cost. Its a good idea to also fit safety wire to secure the exhaust in case the shock mounting fails.
Hawk & Cheetah
Postby Boet » Fri Dec 21, 2007 8:03 pm
It is not a "prop" thing. It is a "heat" and a "2-stroke" thing that makes them fail. :D
