Bushbaby brakes
Mogas
Bushbaby brakes
Postby Mogas » Sun Nov 04, 2007 7:18 pm
I got a new hydraulic brake set from Boet, these were intended for the BMW Explorer but I could not wait to try them :lol:
Old cables.
IMG_0388 (Medium).jpg (56.76 KiB) Viewed 2531 times
Old drums.
IMG_0390 (Medium).jpg (55.96 KiB) Viewed 2528 times
Nottaquitta
Mogas
Postby Mogas » Sun Nov 04, 2007 7:22 pm
And the new stuff.
IMG_0395 (Medium).jpg (56.36 KiB) Viewed 2519 times
Machined clamp brackets which go onto the engine bearer.
IMG_0392 (Medium).jpg (50.75 KiB) Viewed 2516 times
Nottaquitta
Mogas
Postby Mogas » Sun Nov 04, 2007 7:29 pm
The whole lot, new axels, rims, bearings, cylinders and 6 ply tyres probably weigh about a kilo more than the old system but these new axels are much better than the old ones, look a lot stronger.
The new brakes are not bedded in properly yet but braking action is better than the drums so far.
I think that retrofitting like this and useing the standard brake pedals does not get the most out of the system, but then I suppose brakes too sharp would not be ideal.
Nottaquitta
Postby Morph » Sun Nov 04, 2007 10:29 pm
Nice retrofit :lol: 8)
I am very happy with mine, stops the plane very easily.
Aerosan
Postby Aerosan » Mon Nov 05, 2007 6:16 am
Looks sexy :P now..... how much :?: :?: I might just be doing mine as I have one of those outside drum brake setups and ag ja no well :wink:
Mogas
Postby Mogas » Mon Nov 05, 2007 3:33 pm
Old price from Boet was R5500 for the lot + post. Cheap if you consider what is included and compare to the similar Matco product available from Spruce.
Further report: Brakes bedding in nicely now, my new tyres have started creeping on the rims from practicing tail-up stoppies :evil:
My doing though as I lubed tyres, tubes and rims well with talcum powder and run the tyres at 1/2 bar. Will split rims and clean powder off tyre/rim area.
Nottaquitta
Postby Boet » Mon Nov 05, 2007 10:02 pm
I reconfigured the old cable oprated drum brakes. It now keep the BB standing still with the engine running balls-to-the-walls. :D
Mogas, glad to hear you are happy with your brake set. All of it made right here in the "new' RSA. ( Proudly?) It is unfortunate that it sometimes does take long to get all the stuff together to make a COMLETE kit up. We are now looking at a hydraulic brake set, very similar, that can be fitted to the standard BB rims and axles. Price should come down. I will keep you posted. :D
vernon11
Re: Bushbaby brakes
Postby vernon11 » Wed Apr 23, 2008 8:51 pm
Hallo Boet.
Responding to your 5th Nov posting.
Have you come up with the new system yet with the discs that fit the normal rim? We have BBO and would like to fit hydrolic Brakes.
Vernon.
MYR
Re: Bushbaby brakes
Postby MYR » Fri Sep 19, 2008 6:19 pm
Why dindn't you install the cylinders brakes inside the cabin ?
I'm a French speaking person. Sorry for the mistakes I can make.
If you don't understand what I say, do not hesitate to tell me.
Je fréquente aussi le forum : Le forum des ULM-ELA-LSA
Mogas
Re: Bushbaby brakes
Postby Mogas » Sat Sep 20, 2008 12:18 pm
Not enough space between pedals and fire wall for a retrofit.
If planned from new, we build a well into the firewall and fit under the pedals.
Nottaquitta
