VDO fuel gage wiring
Bennie Vorster
Postby Bennie Vorster » Tue Oct 30, 2007 10:10 pm
Does any one have a VDO fuel gage wiring diagram for me please?
I'm strugeling to get mine to work between the two tanks with a switsh. :? :? :?
Bennie Vorster
083 277 5110
grostek
Postby grostek » Wed Oct 31, 2007 6:26 am
Hi Bennie,
Found this, its from the RV site but may be of use to you.
http://www.vansaircraft.com/pdf/Gauge_Install.pdf
Also this from a VW site (VW use VDO)
http://jvila.club.fr/vdo_how.html
Hope it helps.
Kind regards,
Gunter Rostek
grostek
Postby grostek » Wed Oct 31, 2007 7:22 am
Hi Bennie,
Have prepared a drawing showing a two tank set up with switch.
I am no electrician, so get this checked, best person may be your local Auto Electrics place.
Kind regards
Gunter Rostek
VDO Possible two tank set up with switch.pdf
(14.53 KiB) Downloaded 227 times
Bennie Vorster
Postby Bennie Vorster » Wed Oct 31, 2007 7:45 am
grostek wrote:Hi Bennie,
Kind regards
Gunter Rostek
Thank you Gunter, this should do it. :wink:
Bennie Vorster
083 277 5110
Postby Morph » Wed Oct 31, 2007 10:17 am
Bennie,
is this for the BB. If so where did you get the fuel level sensors?
Bennie Vorster
Postby Bennie Vorster » Wed Oct 31, 2007 10:24 am
Morph wrote:Bennie,
Hi Morph
Yes it is for the BB. It came sensors and meter installesd with the plane fitted with the VW motor. We just took out and redid all the instrument panel wiring and now something is not working, I might have the wrong pins on the toggel switsh. :roll:
Bennie Vorster
083 277 5110
Postby Morph » Wed Oct 31, 2007 11:02 am
Interesting,
I'd love to know what sender units they used. I was looking at something similar but couldn't find anything. Anyway, too late now
Bennie Vorster
Postby Bennie Vorster » Wed Oct 31, 2007 7:43 pm
:D Sorted thanks. MGL Have a fuel sender unit that match up with the ff1 fuel computer and cost about R1600. Also a very nice to have on board. :wink: :wink: :wink:
Bennie Vorster
083 277 5110
Postby Boet » Wed Oct 31, 2007 9:29 pm
Ek sit nooit petrol gauges in nie. Net nog iets wat kan lek. Sit net twee liggies in wat teen die tenk skyn, dan kan jy sommer SIEN hoeveel go-go juice nog in jou tenks is. :D
