Quick Question
Quick Question
Postby Gyronaut » Mon Oct 29, 2007 9:15 pm
Please resolve a debate for us: If an aircraft travelling at 80mph goes into a 30degree co-ordinated turn, will the radius of the turn be greater or less than the same aircraft, under the same conditions at 160mph. ?
This of course applies to fixed wings and gyro's alike.
We've contemplated lift vectors and inertia and have no conclusive answer.... please help?
DieselFan
Postby DieselFan » Mon Oct 29, 2007 10:51 pm
Is this a trick question?
If I understand your q properly executing a 30 degree bank Radius would be less, think about it you'd cover much more distance at 160 vs 80mph even if say the time taken to complete a 360 was the same the diameter or radius would be double if not that the circumference should be :wink: .
Higher speed and same bank angle = bigger hole in the sky
What have I missed? Turn without bank? ie rudder...
Rudix
Re: Quick Question
Postby Rudix » Tue Oct 30, 2007 5:38 am
JetRanger wrote:Please resolve a debate for us: If an aircraft travelling at 80mph goes into a 30degree co-ordinated turn, will the radius of the turn be greater or less than the same aircraft, under the same conditions at 160mph. ?
For the same angle of bank the turn radius will be larger the higher the speed, that is why a microlight can "turn on a dime" while a jet fighter uses the whole sky for the same turn.
In your example double the speed will produce a turn +- double the radius, assuming a 1G, co-ordinated turn in both cases.
Fly safe,
DieselFan
Postby DieselFan » Tue Oct 30, 2007 11:49 am
Unless of course you tried to turn with rudder only and are talking about a 30 degree angle when view from above, then you'd have to consider many things like aerodynamics, thrust vectoring etc, you'd also soon get to a speed where you'd just slide with such minimal actual turning that you'd run out of fuel and have to turn using banking to catch that topless merc... :twisted:
Postby Morph » Wed Nov 07, 2007 3:19 pm
Check here for the calculation
http://www.pilotfriend.com/calcs/calcul ... ulator.htm
80mph 30 deg turn will take 40 seconds for a 360 at have a diameter of 1488 feet
160mph 30 deg will take 80 seconds for a 360 and a diameter of 5955 feet, much more.
priester
Re: Quick Question
Postby priester » Fri Nov 09, 2007 7:47 pm
Fly safe,
A 1G turn is not possible :lol:
