what kind of oil?
skydiver
what kind of oil?
Postby skydiver » Mon Oct 08, 2007 4:35 am
What kind of oil is the right one for:
1. the valves on a rotax 582
2. the gearbox on a 582
Postby Duck Rogers » Mon Oct 08, 2007 7:42 pm
The Rotax 2 stroke engines don't have valves but you'll need 2-stroke oil to lubricate the rotary valve shaft which is fed from a seperate container. Use API-TC Classification.
The gearboxes need a good gear oil such as API-GL5 or GL6, SAE 140 EP or 90W - 140 EP. Basically anything over 90 will do.
skydiver
Postby skydiver » Tue Oct 09, 2007 12:05 am
Thanks, Duck.
