Idiot lights
Bacardi
Idiot lights
Postby Bacardi » Sat Aug 04, 2007 5:09 pm
Any TESTED info on connecting Ultrabright LED's on the mag earthing circuits to tell me that I am flooding my trike to the extent that the juice is coming outta the tyres before realising that I had been on full chokes with the mags OFF on starting?
:oops: :oops: :oops:
Bacardi
Postby Bacardi » Sat Aug 04, 2007 5:14 pm
In my defence, I cannot see the mag switches (behind the radio) and had to abort my normal starting sequence because I had to retrieve the ignition key from the rear pocket because of some asshole using my trike's radio when I'm not there and leaving the circuit energised, me having a PAP battery next time out.
John Young
I would move either the radio or the mag switches
Postby John Young » Sun Aug 05, 2007 5:39 am
Bacardi wrote:I cannot see the mag switches (behind the radio) ...
Howdy Bac,
If I were you, I would move either the radio or the mag switches (or both). :idea: :idea: :wink:
I would not fly with your described configuration. :roll:
John ZU-CIB
Bacardi
Postby Bacardi » Sun Aug 05, 2007 1:19 pm
Thanks for the advice, JY. I'll seriously consider the idea, but still think that some nice bright bi-directional hyperbrights will look real snazzy :lol:
What I would like to know, however, since it is not quite clear from the technical data, is what exactly is "earthed" by the mag switches (voltage and waveform is possible) and what effect will a drainage of say 20mA have on the spark generation involved?
Bacardi
Postby Bacardi » Tue Aug 07, 2007 9:50 pm
So, all you gurus out there, and no educated response???
ZULU1
Switches
Postby ZULU1 » Wed Aug 08, 2007 5:29 am
If you really, really must connect a light use a Mag switch with a DPDT connection and connect the idiot lights on the second set of terminals isolated from the engine circuits. All this will do is indicate the position of the switch..
Please fuse them and watch out for smoke ! Why not move the radio as John says..
eish Zulu1
Bacardi
Postby Bacardi » Sun Aug 12, 2007 2:54 pm
A double pole double throw is the simple solution, but if someone can direct me to the what and how much of what we earth with the mag switches, I may just be able to provide a quick and dirty solution that might be of use to others as an add-on without changing the existing hardware configuration.
