Hi guys I have re-built my 503 with new oversized pistons/cylinders and ground run it for 1 hour as per the rotax instructions,
Just wondering when could I consider that the engine is fully bedded
in to be able to carry out an accurate compression test.
Nick.
How long to run-in a 503.
- Look I'm flying
- Duck Rogers
Nick.....about an hour will do.
Check page 63 of the Rotax Installation Manual for the 503. If you don't have the manual, download it from here:http://www.ultralightnews.ca/rotax503/r ... manual.pdf
- KFA
There is a difference between being run in and properly bedded. I would say arround 25-50 hr's for a two stroke and arround 75-100 hours for a four stroke. Just my oppinion.
- Look I'm flying
Hi duck yes thats what I used to cover the 1 hour ground run,
but I was wondering how long does it take for the rings to fully bed in,
did a compression test after the 1 hour ground run and got 100psi cold both pots.
Nick.
Nick.
- Duck Rogers
- Quentin Ferreira
- Look I'm flying
