Once she is running and warmed up there is no problems, she can be started with one hand, its just the initial startup for the day.
Carbs are properly jetted, fuel flow is fine. I have tried starting with choke, without choke, primed it, not primed it, cleaned the plugs etc etc.
I have a suspicion it may be weak spark, or a spark timing issue- how do i know if im on the right track? Are there any checks i can perform to check the spark timing or strength? Perhaps stator coils?
