Faulty Altimeter Guage/recommendation 2 stroke oil
Big Mac
Postby Big Mac » Thu Jun 14, 2007 8:03 am
Hi everyone
Recently bought a Thunderbird and currently training at Ryno Park through
Q Training
Two questions?1) The altimeter guage seems to need a service. Can it be serviced or should I replace it .Who can I contact for the service or replacement.
2) The 2 stroke oil that was used by the previous owner was the expensive synthetic type. Can chainsaw mineral 2 stroke oil be used
The engine is a 618 Rotax
Big Mac
Postby Morph » Thu Jun 14, 2007 8:58 am
Congrats on the purchase 8)
There is a company called Aircraft Instruments. They sell and repair kit
http://www.aircraftinstruments.co.za
Because the 618 is water cooled it needs a two stroke oil designed for this purpose. Castrol Super Outboard would be my choice. Super Chainsaw is for air cooled engines and higher temps.
If you go to your local Castrol Depot (check in the phone book) you can buy directly and by the box. The last time I bought from them I got oil at R10 per 500ml vs R19 to R25 per 500ml at shops and garages.
Have fun and be safe
Postby Tumbleweed » Thu Jun 14, 2007 12:48 pm
I've only used the Halbot synthetic oil in my Rotax 582 since new. Was told will reduce / not build carbon e.t.c.
@ approx R100.00 per bottle, have continued using (off set against booze/ speedfines/ insurance) - so what.
Anyone run a motor on this and had an objective view once opened after 300 hours?
DieselFan
Postby DieselFan » Thu Jun 14, 2007 2:14 pm
Delta VV wrote:I've only used the Halbot synthetic oil in my Rotax 582 since new. Was told will reduce / not build carbon e.t.c.
How big's the bottle? "Normal" fully synthetic is around 250 for 5l - not 2 stroker tho.
Postby Tumbleweed » Thu Jun 14, 2007 8:00 pm
Dunno :oops:
I think 750 ml. Don't pre-mix and has a large resevoir. :wink:
