Mag Switches
Bennie Vorster
Mag Switches
Postby Bennie Vorster » Tue Jun 12, 2007 9:50 pm
:shock: Ok, here I go again, Striped the next plane and now need help to re assemble it. :shock:
I need to re do the wiring on the mag switches. I fitted new switches and just wane make sure that I wired it correct. Please help with a diagram. Does anyone know if it is the negative or the positive power line that is switched threw these switches? :?
Bennie Vorster
083 277 5110
Postby Duck Rogers » Tue Jun 12, 2007 10:34 pm
Ben, what engine are you referring to?
Bennie Vorster
Postby Bennie Vorster » Wed Jun 13, 2007 8:11 am
Duck Rogers wrote:Ben, what engine are you referring to?
Rotax 503 Duel ignition.
Bennie Vorster
083 277 5110
Cloud Warrior
Postby Cloud Warrior » Wed Jun 13, 2007 8:29 am
Rule number one - if you take it apart you had better remember how to put it back together again! :twisted:
Seriously Bennie - my advice (for what its worth) would be to get a person that really knows what they are doing to physically be there to help you. I would not just rely on a diagram to fix this problem. Don't mess around when it comes to squiggly amp thingies!
Bennie Vorster
Postby Bennie Vorster » Wed Jun 13, 2007 8:42 am
Cloud Warrior wrote:Rule number one - if you take it apart you had better remember how to put it back together again! :twisted:
Seriously Henni - my advice (for what its worth) would be to get a person that really knows what they are doing to physically be there to help you. I would not just rely on a diagram to fix this problem. Don't mess around when it comes to squiggly amp thingies!
The remember part I'm not that good with but I do know a little bit of reading diagrams. :wink: :wink: :wink:
Bennie Vorster
083 277 5110
Cloud Warrior
Postby Cloud Warrior » Wed Jun 13, 2007 8:50 am
I thought I might be telling you how to suck eggs :oops: Just don't want to see another statistic that's all!
ZS-NEL
Postby ZS-NEL » Wed Jun 13, 2007 9:11 am
Only have a single ignition wiring diagram can i send you 2 copies? :lol:
perhaps try here http://www.challengers101.com/RotaxChargeSys.html
PMarshall
Postby PMarshall » Wed Jun 13, 2007 9:21 am
Rule of thumb for mags. If everything is disconnected engine should run. So if some wire breaks the engine will still run and you will only be able to stop it by flooding it or starving it of fuel
Hawk & Cheetah
Postby Morph » Wed Jun 13, 2007 9:23 am
Here you go,
The mag switches just connect between the ignition system and earth when 'OFF'. When 'ON' the earth is removed.
BTW if for some reason you start the motor and the mag switches don't kill the ignition use the choke/enricher. This is the only other way to kill the motor except for waiting for it to run out of fuel.
CHII_Wiring_Diagram.pdf
(177.54 KiB) Downloaded 319 times
PMarshall
Postby PMarshall » Wed Jun 13, 2007 9:37 am
As I understand it the mag switch when off earths the coil preventing it from being able to be energised. An intermittend misfire can sometimes be caused by this earthing wire being chaffed through and shorting to earth.
Hawk & Cheetah
Bennie Vorster
Postby Bennie Vorster » Wed Jun 13, 2007 3:00 pm
Morph wrote:Here you go,
Doesn't wanne download Morph. But it makes sense to short the mags to earth if you do want to kill the motor. :wink: :wink: :wink:
Bennie Vorster
083 277 5110
Bennie Vorster
Postby Bennie Vorster » Wed Jun 13, 2007 3:01 pm
Cloud Warrior wrote:I thought I might be telling you how to suck eggs :oops: Just don't want to see another statistic that's all!
Bennie Vorster
083 277 5110
Postby Morph » Wed Jun 13, 2007 4:45 pm
I emailed it to you
Postby Duck Rogers » Wed Jun 13, 2007 8:54 pm
Simple Bennie....the mag wires are not a negative or a positive power line.
They're simply "wires" The ones from the engine go to the one side of the switches and the other side of the switch is run to ground. (individually, of course)
In the "on" position, the mag wires go nowhere. In the "off" position, they're switched to ground.
Bennie Vorster
Postby Bennie Vorster » Thu Jun 14, 2007 7:21 am
A ha thank you guys I'll check it out. :wink:
Bennie Vorster
083 277 5110
