Competition rules...ZULU1 wrote:Every industry needs a "maverick" willing to experiment, this encourages change, puts pressure on existing suppliers to keep them on their toes...the real good thing about this forum is to share views so we all win..
Take a look at the Aero Motor..65hp turbo charged twin cylinder 4 stroke, looks heavy but is effectively altitude compensating and with a 2:1 box will swing a seriously large prop to about 2,000rpm.
There is Smart car in a scrap yard in Verulam at present... go buy it Benny..
keep studyin this enjuneering thing..
Zulu1
The engine per se is not the problem.The Smart engine is cheaper than you think...for the 25k for the car you could get the engine new
Seems like there is quite a few flying over seas.Arnulf wrote:The engine per se is not the problem.The Smart engine is cheaper than you think...for the 25k for the car you could get the engine new
The big problem is that it is a fully electronic motor. The software is mapped to include all the ancilliary sensors from the Smart car. To convert it into an aero engine, the management system must be reprogrammed. The manufacturers are not willing to supply the data to re-map the motor. Apparently it is very difficult to "reverse engeneer" the software and reprogram.
Arnulf
Oom Boet, ek hoor jou. Ek wil net eers gou hierdie ou vw motortjie reg of weg kry.Boet wrote:Bennie, ek sien jy is besig om oor te haal vir die volgende dwaling. Gaan sit stil in die hoek tot die geit gebedaar het, en spaar geldjies bumekaar vir n 582. :D ROTAX RULES!!!!!!
Correct. However it entails more than just to source an engine from the scrapyard, do a few adjustments and implant it into your aerie.Seems like there is quite a few flying over seas.
Agreed but you are no better of flying with a VW motor.Arnulf wrote:DieselFan wrote:You sit with the same problem like with the BMW motor. The manufacturer openly and publicly distances himself from using the engine as an aero engine.Seems like there is quite a few flying over seas.
Arnulf
Exactly. My point. That is why I am not flying with a VW motor.Agreed but you are no better of flying with a VW motor.
Precicely. Also my point. For aviation I use an aviation motor backed by the manufacturer as an aviation motor. For automotive purposes I use an automotive engine backed by the manufacturer as a automotive engine.I think you should split the motors into aviation and non aviation motors and compare appels with appels.
