Fuel flow meter
Mc Guyver
Fuel flow meter
Postby Mc Guyver » Sun May 27, 2007 2:01 am
I have a Skydat as standard equipment fitted to my Airborne XT912
The accumulated fuel flow gives a shortfall of around 14%
This shows excellent fuel consumption instrument wise but would leave you looking for a safe landing spot if going on instruments alone. :twisted:
No operators manual is supplied with the trike but I am sure there must be a way of callibrating the Skydat:?:
Robin Hood
Postby Robin Hood » Sun May 27, 2007 7:19 pm
On the inlet of the unit that measures the actual flow of the fuel there is a jet that has to be pushed in ALL the way till it seats. Otherwise it will give bad readings. Perhaps try that?
cobra
Postby cobra » Sun May 27, 2007 8:23 pm
Robin Hood wrote:On the inlet of the unit that measures the actual flow of the fuel there is a jet that has to be pushed in ALL the way till it seats. Otherwise it will give bad readings. Perhaps try that?
Had the same problem
Robin Hood wrote:...pushed in ALL the way till it seats.
See viewtopic.php?t=2609
Mc Guyver
Postby Mc Guyver » Sat Jun 02, 2007 8:17 am
Hi Guys,
Thanks for the info. Checcked the jet and it is pushed all the way home :x
No change at all in the readings.
Any other suggestions :?: The meter has RS 256 225 on it.
Gaylord Focker
Postby Gaylord Focker » Tue Jun 05, 2007 4:22 pm
Try filling up with diesel ??????
Postby Morph » Tue Jun 05, 2007 4:44 pm
If it looks like the attached pic it is an MGL product.
You will have to calibrate the gauge to the correct factor
support numbers for MGL is +27 21 855 1383 or email info@mglavionics.co.za
AMPtronic
email: amptro@iafrica.com
Tel/Fax : +27 (0)11 679 27 54
Mobile: +27 (0)83 28 28 938
