Welcome back Diesel Fan
- andreb
Nice to have you back in the air DF. I enjoyed our flight on Saturday. Looking forward to many more hours sharing the same airspace.
:D :D :D
:D :D :D
Mooi. What trike is that - Airborne?
Great to see you back in the air
I blame Big D for that picandreb wrote:Sowaar...there really is a brown tinge to the wing!!
High pressure wash for you on Saturday DF.
He said to me "There comes a time in a pilots life when he has to make a large and serious decision and stick by that decision no matter what, to be a man of his word. Clean...or...fly." Ok perhaps not in so many words
BTW How to work out windchill factor, FAJS reports -2 and 44km/h S?
PS
My rotax manual say the engine can go way below zero...but with the bleedy cold, electric starter is hopeless and had to pull start for first time. Is the norm?
- DarkHelmet
Big aeries all use ground power units, so why not the smaller ones
I used to fly an Arrow I. It has a p!ss poor battery starter combo. The battery will swing the prop 10-12 times and then no more. I spent 6 hrs in Bloemhof and managed to flag down a tractor to help jump start (I don't prop metal props if I can help it
) Offered to take farmer for a flip, but he refused - strangely...
Since then I fly with one of these...
Some come with torch, compressor and 12v point. Very useful and it charges on the way to the field in the car's lighter socket. Smaller ones are available and I am sure would fit in pannier (sp?) bags of a trike. Def worth the R400ish bucks. Available at most autospares shops. Will also obviously start the car when you have left the lights on from that pre dawn drive to the field....
2c
2c
When I cranked the starter this morning it was a slow whine like battery was flat from the word go, but it proceeded to crank slowly not slower and slower if you get what I mean. I thort the starter itself was frozen? Normally with a flat bat, it's starts fast and winds down eventually not turning, this kept turning but slowly. At the time it was -3 in the hangar out the wind.
Was it my battery? Yet on Sunday it was on the swing. Took 5 pulls with the rope, thereafter electic starter was fine
- Tumbleweed
Yip did radiator flush in Feb, same day as a GT450 flew overdemon wrote:I always have one of those portable jump starts in the hangar and on away trips. Hand starting a 912S is just not possible![]()
Do you have antifreeze in the coolant DF? It does sound like the battery tho.
Go to Dions or Makro and get one the portable jump starters
I will check again tomorrow morning. Like I said earlier normal battery symptoms are the turning gets slower and slower as battery power drains. Here the starter was turning slow. I swung for 10 secs, then waited 2 mins, swung for 10 secs, both times there was no audible or visible change in the swinging speed. After trying manual via rope stater was fine.
Lets see what happens tomorrow, it's meant to be even colder, so good test.
Users browsing this forum: No registered users and 38 guests
