Straydogs GT450 may have hit Jhb-Dbn record ?
ZULU1
Postby ZULU1 » Wed May 16, 2007 8:45 pm
Straydog pitched up today Jhb-Ballito total flying time 3hrs 55mins..Is this a trike record ?
gijima Zulu1
Postby RV4ker (RIP) » Wed May 16, 2007 9:35 pm
Where exactly from and to. (Co-ords will help) The official trike WORLD Speed over a closed circuit of 50 km without landing : 146.7 km/h, set recently by GT450. (Demon you snoozed) :twisted: :twisted: :twisted:
Date of flight: 21/08/2006
Pilot: Richard MEREDITH-HARDY (UK)
Course/place: Bonneville Salt Flats, UT (USA)
Microlight:
P & M Quik GT 450
Speed over a closed circuit of 100 km without landing : 129.11 km/h
Microlight:
ESO 13
Speed over a closed circuit of 500 km without landing : 100.33 km/h
Based on assumption of springs to Balito, it is around 115km/h. If it was 50km further and he did all the paperwork beforehand he coupld possibly have claimed the world record for flight over 500km closed course...
With the plethora of new 450's in SA this may be worth looking at... http://records.fai.org/microlight/
All the current records at http://records.fai.org/microlight/current.asp?id=RWL2.
There are none in SA, so YES this would have been the offical record for the Jhb - Durbs route in SA...
Maybe Mike B can shed some light on the above and how it works. I assume MISASA is the appointed affiliate of the FAI WRT microlights (Class R) in SA? Here is the link for the power flying boys (Class C) http://www.sapfa.org.za/records/records_rules.php
I am (later in the year when things calm down a bit) planning to have a go on a weekend at setting all the single eng piston resords in SA. . Not tough, since there are none :oops: :oops: :oops: , but just to get it on the map. may also be fun as the same courses required are set out for each class of aerie. (Trikes, single, duel, 3 axis, land, sea etc) Maybe have it as part of a fly away. Kalahari Bundu bash would have been perfect, but it too close to PTAR :oops:
The following flights are recognised for purposes of records
* Distance Records
o Distance without landing.
o Distance over a closed circuit without landing.
* Altitude Records
o Altitude without payload.
o Altitude, aeroplane launched from ship.
o Altitude in horizontal flight without payload.
o Altitude with payload.
o Greatest payload carried to height of 2 000 and 15 000 metres.
o Time to climb to various heights.
* Speed Records
o Speed over a straight 3 kilometre course at restricted altitude.
o Speed over straight course with minimum length 15 kilometres and maximum length 25 kilometres.
o Speed over closed circuit, without landing. Course lengths are 100, 500, 1 000, 2 000, 5 000 and then by increases of 5 000 kilometres.
o Speed over closed circuit, without landing. Course lengths are 100, 500, 1 000, 2 000, 5 000 and 10 000 kilometres without payload.
o Speed around the world, non stop and non refuelled
o Speed around the world, eastbound and westbound
o Speed around the world over both the Earth's poles
o Speed over commercial air route.
o Speed over commercial air route in excess of 6 500 kilometres.
o Speed over recognised courses.
The Aero Club of South Africa has designated flights between the major cities in South Africa as recognised courses. The cities designated are Bloemfontein, Cape Town, Durban, East London, George, Johannesburg, Kimberley, Nelspruit, Polokwane, Port Elizabeth, and Pretoria. Flights between certain of these cities are under the minimum 400 kilometer distance and no record will be allocated for them.
lamercyfly
Postby lamercyfly » Sat May 19, 2007 8:07 pm
Nice speed.
I did Solitude Airfield to La Mercy in 4hours 6mins (4.1 on the hobbs) in an Aircreation Racer fitted with 503 motor.
Route flown was Solitude, Heidelberg, Standerton, Newcastle, Dundee, La Mercy.
This time included circuits and taxi time at Standerton and Newcastle where I topped up fuel.
Actual flying was about 3.9hobbs.
After figuring out my consumption, I calculated that it was safe to do Newcastle - La Mercy in one stop.
This time was made possible by strong North Westerly winds.
My average IAS was 65mph.
:lol:
Later,
David Daniel
Email: lamercyfly@gmail.com
Mobile: +27 (0)746495744
