New Gyro Flying
New Gyro Flying
After many months of hard work from the guy's at Rhino and a few setbacks the Xenon took the the air yesterday just after 10:00.
As a bystander I was more nervous than the test pilot who did a thorough job and the machine sounded awsome.
After two test flights the red baron was put away in the hanger and all were pleased with the performance.
It sounds different with the type of prop fitted and very quiet in the air.
- DSC05210.JPG (67.87 KiB) Viewed 2095 times
Empty Toy Box
Busy Arranging for new toy.
Graham Cooper
Graham Cooper
re
Who was the test pilot ?
- Thunderboy
- Low Level
Very similar to 3-axis. Stick and rudder control - without the flaps part. :DSo, how does one fly a Gyro?
No, flying is very easy, coming back is the difficult part.Is it difficult?
Do you consider it more dangerous than a trike?
Do not have any trike experience, but from what I've seen, read, and experienced in a gyro, my 2c. On the ground, take-off and landing, if you stick to the rules - no. In the air, much safer than a trike because of the bad weather handling characteristics. 99 % of accidents and incidents in a gyro is during take-off and landing.
Experienced pilots will land it in your back yard, zero ground roll. Unfortunately it must have an approach, cannot land with a vertical approach, unless with a stiff headwind. Student pilots land it with about 5 - 10 meter roll.How small an area can you land in?
As trikes and planes, take-off depends totally on weight, weather, wind and height ASL. We fly at 5300 ft ASL, 2 up and take-off roll is 150-200m.How small an area for take off?
At sea level I understand take-off to be 50m.
Can you hover?
Yes, but you lose height. It can hover, and retains it height in a stiff headwind - 30 knts or so - seen a video of it even flying backwards.
Looks fantastic!
For normal salary earning mortals the most fun you can have in the air - my opinion.
ZU-CFW
ZU-CFW
- Low Level
This videos will give you an idea of gyro flying:
http://www.youtube.com/watch?v=sl1CssG_7bg
http://www.youtube.com/watch?v=9PI92o6f-iU
http://www.youtube.com/watch?v=YtcezQaxb_w
http://www.youtube.com/watch?v=iJjfAgnaKC8
ZU-CFW
ZU-CFW
Have they fixed price in SA RONT?
- Gyronaut
Gyro's simply provide the safest, most fun you can have with your clothes on. As a former HPPL holder I can categorically state that they are safer than helicopters since they are always in autoration. Todays designs virtually illiminate Power-Push-Over (PPO) and Pilot Induced Oscillation (PIO) with their large vertical stabilisers. The only thing they dont like to do (although they are capable under certain circumstances) is the one thing that helicopter pilots hate doing because of the inherent dangers, and thats hover.
