Can anyone give me a quick rundown of the following:
What does QNH stand for?
What effect does it have on the plane if it's high or low?
QNH (Questions Need Hanswers)
Query Nautical Height, i.e. the height above sea level. Here you set your altimeter to the known height an airfield has above sea level before take off. The altimeter will show altitude as AMSL (above mean sea level)
QFE is Query Field Elevation, Here you set your altimeter to 0ft while at the airfield. It will thus show altitude as AGL (Above Ground Level)
I dont think I was particularly clear on my previous post.
Before flying you set your altimeter to the known altitude of the airfield. the little gauge on the altimeter then gives you a reading in Millibars which represents the air pressure at that particular place. A higher aipressure indicates stable conditions and lower air pressure indicates unstable conditions and the possibility of a cold front. It is better to fly in higher pressure conditions.
- ZULU1
All the Answers
Take a look at this site, it has everything you need to know about "Q" codes and origins of same : http://www.kloth.net/radio/qcodes.php
except QUANTAS !!
eish Zulu1
except QUANTAS !!
eish Zulu1
- John Young
- The Boss
Better on a camel
S uch
A
B loody
E xperience
N ever
A gain
B end
O ver
A gain
C aptain
B etter
O n
A
C amel
L et
U s
F ook
T he
H ostess
A nd
N ot
S ay
A nything
A
B loody
E xperience
N ever
A gain
B end
O ver
A gain
C aptain
B etter
O n
A
C amel
L et
U s
F ook
T he
H ostess
A nd
N ot
S ay
A nything
