Brakes on a trike + Weight issues
JACO
Postby JACO » Wed Mar 21, 2007 8:01 pm
Hi all, I was wondering, and spoke to a few people about removing my trike's front wheel brake, and replacing it with rear wheel brakes, But the folks around here has mixed feelings on the matter, some say yes, some say no. Would'nt distrubuting the "brake" weight to the rear wheels be better that all the weight on the front wheel ??
Next, My trike's silver top 582 is mounted very high, thus increasing the "top heavy" effect. Why is some engines way up there and others lower down ?? Can I turn myne upside down ??
Thanx
Engine high.JPG (33.02 KiB) Viewed 2440 times
Miskiet
Postby Miskiet » Thu Mar 22, 2007 8:35 am
I met a guy at Delmas airfield once (I think he flew in from Secunda or Witbank) that had a Raptor with hydraulic brakes (disks) on the rear wheels only - he said they were awesome and an improvement on the front brake.
Having your engine high is a plus! Wish I could turn my Windlass engine right side up! Changing spark plugs is a hassle upside down. You will also have better prop clearance with yours right side up (less chance of damaging prop on a stone thrown up by the wheels). Have a look at Aquilla's and check how high their engines are - this is not a problem.
Biggles
Postby Biggles » Thu Mar 22, 2007 11:31 am
JACO,
Looks like you have room to play with as your gearbox is mounted so the prop axis is below the crank axis, So you could lower the engine and turn the gear box around and you have a lower engine and the same clearance.
But my motto is leave well enough alone.
Trike pilot
ZU-DLP
Winelands FAWN
gertcoetzee
Postby gertcoetzee » Thu Mar 22, 2007 1:36 pm
Proper disk breaks on the back wheels on the Aquilla! Now that would be worth investing in.
taaipitperske
Postby taaipitperske » Thu Mar 22, 2007 2:04 pm
As 'n voertuig / bewegende voorwerp rem, is die grootste gewigsverspreiding outomaties op die voorste wiele. Daarom dat "brake calipers" so ontwikkel is.
Dit is een van die voordele van 'n rem op die voorwiel - 'n rem op die wiel wat die meeste gewig dra.
'n Remstelsel op die agterwiele kan werk, maar hou in gedagte dat indien een wiel vir een of ander rede meer 'byt' as die ander een, kan die trike lelik van koers gegooi word.
Arnulf
Postby Arnulf » Thu Mar 22, 2007 8:09 pm
Taaipitperske het geskryf:
By n vliegtuig is die neuswiel algemeen die swakste punt, en dit dra die minste gewig. Die agterwiele baie meer effektief vir briekdoeleindes. Al die nuwe "upmarket" trikes het hidrouliese remme agter, en dit werk baie goed.
Groete na Suidwes.
This is a project that is being seriously attended to. Will keep you posted.
Arnulf
Dre'man
Postby Dre'man » Thu Mar 22, 2007 8:36 pm
You should have a look at some of the braking systems on quads, the discs are small but have awesome stopping power.
And above in nothing
