make trike faster
Massimo
make trike faster
Postby Massimo » Mon Feb 26, 2007 2:07 pm
Yes cruising in a trike is amazing but when you eventually want to get somwhere it can take a while, sooo i want to make my trike cruise a little faster, so what are the options. And no im not buying a GT450 or any other plane. Im thinking along the lines of electric trim, front pod, what else, and no new motor either? please suggest along with price and what speed it should add.
I hear many tirkes are cruisinbg at 70 miles, how do you do it. The only way i get that right is by removing the nose cone and pulling serious bar!
Currently have aquilla with 582 motor. :roll:
DieselFan
Postby DieselFan » Mon Feb 26, 2007 3:35 pm
Hmm, my manual has in BIG BOLD LETTERS DO NOT REMOVE THE NOSE CONE but then again that affects the internal pressure and my wing is slightly different, it's got wierd pieces of material inside. My trim system doesn't speed up it merely slows it down about 5-8mph
Pod makes about 3-5mph dif, but around 2-3l on fuel...
Hang point about 3mph per point.
Give Jenya a chat he has sped up many wings.
Dreamer
Postby Dreamer » Mon Feb 26, 2007 4:46 pm
Flames, you have to paint flames on the pod :D .......
A new resident at Microland
If the runway is wider than it is long, rethink your circuit.
Massimo
speed
Postby Massimo » Tue Feb 27, 2007 8:58 am
Hmmmm.....looks like my options are GT450 or GT450
Its an Aquilla 582 with Aquilla 1 wing, trike is 2 yrs old with 260 hours.
Thanks Deisel will talk to Jenya (at petit?)
Hey Dreamer will you do the paint job, im not too good with art?
Demon what is mylar? :roll:
Bumpy
Postby Bumpy » Tue Feb 27, 2007 9:38 am
What you need is R300 000.00, if that doesn't fix it get used to going slowly :lol:
How do mosquitoes get this high?
DieselFan
Postby DieselFan » Tue Feb 27, 2007 11:30 am
Instead of buying a new trike you could always just change the wing, Jenya has loads of experience doing this.
Some wings to look at if you want faster than Aquilla
Italian Hazzard 12m2 - for serious speed
Air Creation XP wings 12m2 or even Ixess 15m2, mine is a XP15 and cruises around 60 bar in full 2 up will see 90 - stall at 40.
Aeros Profi 14.5m2
NEW Spirit 15
I know of Aquillas around the world flying with these wings. They cost from 45k to 80k. Most around the 50 mark.
