Jet mictolight
Slider
Jet mictolight
Postby Slider » Thu Dec 21, 2006 7:06 am
Ok now this is scary. I wonder if this could actually work on a microlight :lol: :lol: :lol: :lol: :lol:
http://www.break.com/index/jet_propelled_bicycle.html
Yeah right, maybe 10 of them...........................
ZU-ALW
Hanger 5-7
Microland
120.35
The Agent
Postby The Agent » Thu Dec 21, 2006 4:09 pm
Awsome delivery bike and fast.
Empty Toy Box
Busy Arranging for new toy.
Graham Cooper
FAWGie
Postby FAWGie » Tue Jan 02, 2007 7:56 am
He needs an afterburner....
smallfly
Postby smallfly » Tue Jan 02, 2007 10:15 am
I am still of the opinion that one could power a microlight on these
engines.Think in the line of a teenie or kr2 fitted with two 20 lbs jetcats
under aech wing.If the kri-kri can fly on two, surely a kr2 can fly on four,
or for that matter, two jetcats with afterburners? :roll: :roll:
DieselFan
Postby DieselFan » Tue Jan 02, 2007 11:07 am
SO instead of cutting the grass with our props we'd light the firebreaks? :twisted: Actually I've got a clip of a mosquito fitted with a jet engine - looks cool
Postby Tailspin » Tue Jan 02, 2007 11:09 am
I would say you can power certain microlights with this type of motor, i think your biggest problem would be the weight and balance. Also the VNE. OOps lets not forget explaining to the CAA how a jet powered aircraft can be registered under the microlight catagory EISH :?: :?: :shock:
Dre'man
Postby Dre'man » Tue Jan 02, 2007 11:17 am
How do you stop the heat burning the fabric on a 3 axis, :?: unless mounting on the tail :shock: I would love to see people faces when a trike flies by with a jet engine :twisted: 8)
And above in nothing
DieselFan
Postby DieselFan » Tue Jan 02, 2007 11:59 am
Here's a pic from the clip 2 mins long...will get the original URL
Jet powered Mosquito
loansharkblv
Postby loansharkblv » Tue Jan 02, 2007 4:42 pm
Bryan Nel
Kwelega - East London ( 124.8 )
The Agent
Postby The Agent » Tue Jan 02, 2007 4:46 pm
Ja Boet and welcome back Bryan.
Empty Toy Box
Graham Cooper
smallfly
Postby smallfly » Tue Jan 02, 2007 6:42 pm
Dre'man wrote:How do you stop the heat burning the fabric on a 3 axis, :?: unless mounting on the tail :shock: I would love to see people faces when a trike flies by with a jet engine :twisted: 8)
Id stick to blik like teenie, but in the clip one guy is holding his hand behind it, directly in line with the backblast and it doesn't look like he burned, so vertically upwards it should be cooler, especially taking into consideration the overflow of air being dragged over the motor as a result of the venturi action. Now if you mount the motor on a pantograph, where up and down movement of the wing is repeated by the motor, not only will the wing be out of harms way, but you will also have more efficient maneuverabillity, because thrust will always be directed towards the direction of steer in the same way as the directional nozzle in use on the new generetion american jetfighters.
To answer tailspin's question, you don't register as microlight, but as experimental.
