912 performance question
Postby Morph » Tue Nov 21, 2006 10:45 am
I think I have the 2.273 ratio gearbox in my 912UL motor. I have been told it is better to have the 2.43 ratio box.
I have been told that the 2.273 ratio runs rough between 4300 to 4800 rpm with the roughest patch being at 4500. :shock: which is the rpm that most guys want to cruise at. I have also been told by Pieter De Necker that the 2.43 ratio will swing a fatter prop giving more thrust.
Now apart from this what performance difference should I expect between the two ratios. Obviously I can see the prop will spin faster per rpm on the 2.27. A faster spinning prop in my mind equates to a better climb performance but not cruise
Who of you is experienced on the 912 80HP motor and the two ratios?
Postby Boet » Sun Dec 17, 2006 12:09 am
Yes the 2.43:1 ratio is the better one. Try it first with the 2.27. It SHOULD be OK with the 3-blade Ivo-prop. It is hellishly expensive to change gears.....
The 2-blade props is very rough on certain ref ranges. True. I have not noticed this on 2-bladers. Get the aerie finished so we can begin test flying!! :D :D
Postby Morph » Sun Dec 17, 2006 9:25 pm
I've taken your advise, this is not a big job, it's a sh!tload of small jobs :wink: :lol:
See you in the air soon
