Postby ZULU1 » Sun Nov 12, 2006 7:51 pm
Hiya
Th green light indicated that that particular frequency is "open" either receiving a signal or that the squelch is in fact open. I may assume that you have adjusted the squelch to close or extinguish the light. Try the following:
1/ Is the antenaa connected to an external antenna, if so face it slightly forward,
2/ Turn the ANL "on"
3/ Increase the squelch level so the light extinguishes, this may be caused by other electronic GPS systems, if you have a 296 then you will need some rf beads. However it is a Black art and can be tedious. I always win but normally a rf bead will fix it without other additions.. I swear by them. See previous threads regarding cutting cables.
try these first but not on plane power....or give me a call.
Ciao Paul (Air Magic) (032) 525 5168
