Live Long and Prosper Earthlings,
I have now heard of B, C and E gearboxes.
Unfortunately I have no clue what the diffirences between them are.
Could someone help my out of my misery regarding this.
Please Explain Gearbox Types
- Duck Rogers
Here's a basic overview.......there may be other differences also between the boxes, but you'll get the picture anyway :D
The B box is easy to identify as you have six nuts/bolts holding the two halves of the box together.
They are (were) availble in two types: the provision 4 which has an adapter plate bolted to the engine and the gear box bolts to it, and aprovision 8 which uses 8 bolts and NO adapter plate - the box bolts
directly to the engine.
The B Box is also regarded as a lightweight box and is probably best suited for props with a length of 66" or less. Also has no "rubber donut" damper.
Then you get the C and E boxes. Designed for longer/larger props with more rotational mass. These have a series of small allen screws holding the gear box halves together, and have a "rubber donut" damper between the output shaft and gear box to absorb the loads that the larger props are placing on the engine. The E box is basically a C box but has a built in electric starter and is the best in my opinion.
The C and E boxes are regarded as heavyweight boxes. (not because they're heavier
The boxes are also offered in different gear ratios.
There is also an A box which is no longer manufactured.
Spongebob.....you can stop being miserable now :D
- Duck Rogers
The Rotax spec calls for a gear oil with a rating of API-GL5 or GL SAE 140EP or 85W140EP. Usually any good gear oil with a "weight" of 90 or higher will do just fine. Get it at your local petrol station unless you want to stick to the specs and go and buy moerse expensive Castrol stuff.Tobie wrote:...what is the best oil to use and how often replaced? E-box.
If you have a new box, replace the oil after the first 10 hours of operation and thereafter every 100 hours
