582 and WARP drive
Aerosan
582 and WARP drive
Postby Aerosan » Tue Oct 03, 2006 3:26 pm
Just a question, is there anyone here that runs a 68" 3 blade warp drive on a 582? Junkie posted a while ago that his setting is 21degrees 50cm from the bolts. But he has a 62" warp and I think a 3.47 drive. I dont get anywhere near that :shock: Im at 11 degrees AT THE TIP with a 2.93 beld drive. Piet prop recons it is just about right. puff I rev 6200 static so it does sort of check out but I would feel a hell of a lot better if someone could confirm that :D
10 000 zim dollars to the one who gives me the right answer :twisted:
Cheers San
John Young
Re: 582 and WARP drive
Postby John Young » Tue Oct 03, 2006 4:45 pm
Aerosan wrote:I rev 6200 static so it does sort of check out but I would feel a hell of a lot better if someone could confirm that
I have the same config. and rev at 6,200 rpm static as well. All the boffins are happy with that.
John ZU-CIB
Postby Duck Rogers » Tue Oct 03, 2006 7:14 pm
John Young wrote:I have the same config. and rev at 6,200 rpm static as well. All the boffins are happy with that.
Well done John! You just earned yourself ZAR 5.00
Wish it was me.....
John Young
OOMpie Quack
Postby John Young » Tue Oct 03, 2006 7:45 pm
OOMpie Quack,
You are 3 years "outta" date.
10,000 Zim Dollars now worth R 0000.05 - Eish !!
John ZU-CIB
Aerosan
Postby Aerosan » Wed Oct 04, 2006 6:23 am
Hi John
Please ignore the Duck you know at his age :roll: he might know more, the problem is he doent know where he put it:!: anyway what is your pitch at the tip of the blade? or are you saying that your config including the pitch etc. is excactly the same:?:
Thanx for your help
San
John Young
We Microlight junkies are just not good enough
Postby John Young » Sat Oct 07, 2006 12:21 pm
Aerosan wrote:Are you saying that your config including the pitch etc. is excactly the same:?:
Hi San,
We Microlight junkies are just not good enough to be able to determine “exactly the same”. :lol:
Simplified, [assuming a well maintained engine and ancillaries], 6200 rpm on a 582 should be delivering maximum static thrust at the business end.
I have not had a need to measure nor adjust mine since purchase – although I do have all the books and gauges here.
John ZU-CIB
