Transponder ADS-B
rwaldeck
Heard about flying
Transponder ADS-B
Postby rwaldeck » Mon Jan 21, 2019 8:17 pm
Hi
I’ll be moving my Gyroplane to Virginia Airport and need to fit a Transponder.
Transponders are expensive and I only want to do/fit it once.
With the forthcoming requirements (in 2020?) for ADS-B (enhanced Mode S with the 1090ES modification) capability,
which Make & models should I look at and where to buy ? Plse advise,
Magni M-22
ZU-RDE
Happyfeet
Found a flight school
Re: Transponder ADS-B
Postby Happyfeet » Sun Jun 11, 2023 3:17 am
Trig T21 or T22 with TN72 and DA 50 antenna.
Would set you back around R50k.
Adsb out.
If you want Adsb in and out you can go sky Echo with IPad with trig 21 transponder. But that configure will ensure a 40nm range.
Other options are Garmin gtx 345 or stratus es. But now your talking R60K plus.
I just upgrade my trike wit trig system. That's why I know what the price are.
