It is that time of the year again.
No different from previous years.
Arrivals Friday. Foodstalls will be opperational from midday Friday.
Visit around the fires with a braai and soup.
Saturday more arrivals. The whole day of fun flying and meeting up with like minded friends. Foodstalls with a variety of eats.
Evening around the fire with braai.
Sunday morning breakdast roll and then departures.
Atc will be on Saturday only. 120.20
Listen in from 10nm inbound and report 5nm inbound.
The other times unmanned procedure join 2000ft agl (5900) for windsock inspection and desend on the southern side of 10/28 as both circuits are to the north.
Camping on the field wiyh hot showers and ablutions.
Guesthouse in town with details to follow.
You miss this you realy will miss out.
We are looking forward to hosting you all once again..
Taildraggers to Nylstroom 13_15 July 2018
Balls to the wall
Balls to the wall
- nicow
Re: Taildraggers to Nylstroom 13_15 July 2018
En die Potties Patrollie beplan om weer die jaar daar te wees...
Kan nie wag nie
Less than a week to go!!
Balls to the wall
Balls to the wall
Thanx Richard and Crew for a wonderful event once again
ZU - ATE Windlass 503
ZU - CHG Aquilla 582
ZU - BAJ Bushbaby
ZU - BAJ Bushbaby
En waar is die fotos, asb. Ek is by die huis met groot griep!
Thunderbird
Bushbaby in rebuild
Bushbaby in rebuild
Baie Dankie aan Nylstroom vliegklub vir n lekker naweek, net jammer weer het nie heeltemal saam gespeel nie. +/-90 vliegtuie daar gewees
Kan nie foto’s post hulle is te groot. Kan WA as jy jou nommer stuur
- nicow
Die Potties Patrollie was darm ook daar...
Thanks for all that attended.
Potties Patrollie julle is verseker die meeste van een klub om in te vlieg.
It was great. Pity about the treat of bad weather in the Joburg area that scared the Joburgers back home.
Till next time Nr 10
Balls to the wall
Balls to the wall
