VW engine mount wanted
Use this topic if you are in the market for something
P Pilot
Postby P Pilot » Tue May 29, 2018 6:45 am
Good day,
I am looking for a tubular engine mount for a VW for my VP1 project.
Anything from a KR, Cubby, Sonerai or similar should do the trick - or at least be a good starting point.
Thanks!
Kingfisher
Re: VW engine mount wanted
Postby Kingfisher » Fri Jun 01, 2018 9:05 am
The VW engine on a VP bolts directly to the firewall with aluminium spacers between the motor and the firewall if my memory serves me correct. Check the plans, sure I'm correct. If you move the motor forward the centre of gravity will change from the original design.
Bosvark
Postby Bosvark » Tue Jun 19, 2018 9:22 pm
You are
Rhino? Fck the Rhino, save the White Ou.
(met permissie van Gyronaught)
