I need a prop for a rotax 503 or 582. ie., RH pusher.
'E' or 'C' Gearbox, 1:3.47 ratio. 72inch or 1.82m diameter.
I am also looking for 1 or 2 blades RH pusher blades called Aero. They have the little winglets on the end.. I have the hub, plus 2 good blades and need to make up the set..
Please spread the word..If you know of some-one who has had an 'oopsie', ask them..
Thanks.
David]
propeller needed
- lamercyfly
- Top Gun
Re: propeller needed
Dear David,
Usually we recommend for this reducer (3,47):
Rotax-503 is a 3-blade propeller with a diameter of 1700 mm
Rotax-582 is a 3-blade propeller with a diameter of 1750 mm.
Diameter 1820 is recommended for a ratio of 4.
