Skywares - Grippa Aircraft Tie Downs
Alpha
Postby Alpha » Mon Apr 24, 2017 11:37 am
Hi All,
Skywares will run this easter special for 1 week only...
Full set of grippa Tie downs as per the pic
R1450
Full set of Mini Grippas perfect for the trike fly aways...
R650
Mini Grippas.jpg (9.65 KiB) Viewed 751 times
ZS-WGT
ZU-AAS
Re: Skywares - Grippa Aircraft Tie Downs
Postby Madman » Mon Apr 24, 2017 12:24 pm
I can vouch for this setup as I have never seen any other set grip like the Grippa. The Witbank Bank Boyz will also confirm that the Grippa holds even in mud ## ## ##
What makes this setup awesome is that it pulls tighter into the ground the more you or the wind tries to pull it out...really awesome and you can sleep well knowing your bird will still be there and in once piece the next morning =D*
Once off awesome buy that will probably last you forever ^*^^
Tied Down
Tied Down
