Flying helmet wanted
grantr
Postby grantr » Wed Apr 19, 2017 7:50 pm
Hi All
I bought a Microlight and the noise level even with Bose A20 is high. Radio is a problem at the noise levels. Anyone have a helmet solution? Call 0 eight two 414008 seven. Thanks
John.com
Re: Flying helmet wanted
Postby John.com » Thu Apr 20, 2017 6:40 am
grantr wrote:Hi All
Hi Grant, sadly to say the Bose A20 noise cancellation will not work in an open cockpit environment. I learnt a very expensive lesson and still have both my Bose A20s mothballed for my PPL a little later.
Finding a helmet which is comfortable when worn OVER a headset was also a challenge for me. Some guys seem ok with the solution, but it never worked well for me. Also, in the case of the Bose A20, it has a very thick plastic headband that tends to cause discomfort when worn under a helmet.
I have opted for an integrated headset/helmet solution from Italy (designed for paraglider pilots http://www.icaro2000.com), which still comes in cheaper than a set of Bose A20s and works like a dream! Comfort and perfect sound clarity! #GAMECHANGER
Cheers, John
John Comley
Magaliesberg, South Africa
wackomedic911
Postby wackomedic911 » Thu Apr 20, 2017 8:45 am
John.com wrote:
grantr wrote:Hi All
Cheers, John
Hi John, are these available locally or does one need to import?
thanks!
ZU-CEK
— Amelia Earhart
John.com
Postby John.com » Thu Apr 20, 2017 9:09 am
wackomedic911 wrote:
John.com wrote:
grantr wrote:Hi All
Cheers, John
thanks!
Sadly, you need to import. They build them to order, and order in the headset option you select from a third party supplier, so expect 6-8 weeks.
Another really nice feature is that it truly is a one-size-fits-all, as they come with inserts for the various head sizes.
Oh, also, the 'rollbar' option for face protection (see image below)
I have two in the Hartebeespoort area, and would be happy to let you trial one so as to eliminate the risk of importing a helmet 'blind', so let me know. Dual-socket connector option.
Out of interest, the Icaro 2000 helmets were used in the solar powered around the world flight (http://www.solarimpulse.com)
see sample Icaro 2000 helmet here
Regards, John
John Comley
grantr
Postby grantr » Thu Apr 20, 2017 9:33 am
Thank you for your king input. At least there is a solution and I will now go find iy
wackomedic911
Postby wackomedic911 » Thu Apr 20, 2017 9:42 am
Thanks John. Wich ones do you have?
They look quite nice so i might go this route too.
ZU-CEK
— Amelia Earhart
John.com
Postby John.com » Fri Apr 21, 2017 4:27 am
wackomedic911 wrote:Thanks John. Wich ones do you have?
I bit the bullet and got two of the carbon fibre finish version of the Omega 2. Sheer luxury compared to anything else available. http://icaro2000.com/Products/Helmets/Omega/Omega.htm
Let me say again, they are fairly pricey (to avoid 'Nkandla duties' I had mine shipped to the U.K. and then brought them back with me after a business trip).
However, the difference in comfort and voice quality is remarkable.
Out of interest, for a nominal amount extra, I ordered the under-chin skirt that zips closed off the rollbar, which makes winter flying in SA just that much more tolerable.
Also, as a final comment, the Omega 2 helmet, being 'full-face' and with ears fully enclosed does take a little getting used to, but once flying it is heaven!!
John Comley
