Rotary atomisers for sale
Re: Rotary atomisers for sale
The new atomizer is disassembled and assembled in one motion:
I want to emphasize that the atomizer blades are made of carbon fiber and are practically not damaged even in case of accidents. Of course, they have a huge lifespan.
A new atomizer is easily disassembled and assembled::
More foto
The agricultural season is over with us. The last pumps, sprays, cranes are sent. The download has decreased. Therefore, we will gladly fulfill your orders.
We continue to produce pumps and sprayers for agricultural aviation. We also produce spray equipment for biological plant protection products.
Do you use biological plant protection products?
Give me a breakdown for spares and price for a 75mph aeroplane for spray equipment and how much fluid do you put down /ha and the width of one pass
Usually we work with a processing width of 20-25 m and a consumption of 4 liters per 1 ha. The working speed is about 100-110 km / h.
Atomizers and pump allow to regulate the flow rate from 2 to 10 l / ha. We also use them on planes with a working speed of 150-160 km / h (type An-2).
The price of the atomizer is 220. The pump is 200. The electric crane is 200. Special keys are 25. The protractor for setting the angles of the blades is 25.
https://www.youtube.com/watch?v=QOOxHtJCI3I
What is your plane? Rans S-7?
We mostly use the X-32, it has similar characteristics.
what is the delivery of your pump and at what pressure
1. La pompe centrifuge chimique, poids 1 kg, consommation. courant pas plus de 10 A, tension d'alimentation 12-14 V, la consommation d'énergie ne dépasse pas 140 W, esclave. pression 0,9-1 kg/cm2, productivité moyenne - 30 l / min
2. Pompe à engrenage chimique: débit 50 l/min à une pression de 5 atm. Le poids total est de 9,5 kg. Puissance - 600-800 watts. Current - 50 A. Voltage 12/27 V.
1. The chemical centrifugal pump, weight 1 kg, consumption. current no more than 10 A, supply voltage 12-14 V, power consumption no more than 140 W, slave. pressure 0.9-1 kg/cm2, average productivity - 30 l/min
2. Chemical gear pump: flow rate 50 l/min at a pressure of 5 atm. The total weight is 9.5 kg. Power - 600-800 watts. Current - 50 A. Voltage 12/27 V.
We have started the season of agricultural work. All orders became urgent. Nevertheless, we continue to send pumps and atomizers to other countries.
We have begun work on desiccation of sunflower. There are a lot of works. Consumption - 5 l / ha.
The photo shows the use of poisons on wheat.
- опыл10-.JPG (26.19 KiB) Viewed 4803 times
- опыл-.jpg (38.26 KiB) Viewed 4803 times
- опыл4-.JPG (29.53 KiB) Viewed 4803 times
We have winter now, snow is waist-high. Aircraft rest. But agricultural equipment is already preparing for work.
As far as I know, it's winter now, so this photo is very useful
Users browsing this forum: No registered users and 106 guests
